Tractor Talk Discussion Forum
tim in wi
Farmer in the D
09-27-2004 10:48:03
Hey Tim,
No real suprise that it took another Wisconsinite to answer a JD Sled Q. Wanted to ask what your symptoms were? Was it a 340? Why 3 times and in what time frame? Have no problem jumping in but want to make sure I do my homework first. Thanks
tim in wi
09-28-2004 04:09:29
 Re: tim in wi in reply to Farmer in the Dells (WI), 09-27-2004 10:48:03
340 1973 a/ cat panther 90 93 95 flooding run on 1cyl just about fill crankcase with gas o-ring failed havent run it in yrs no snow or about the time i start to get it out it melts gl tim
09-28-2004 08:50:30
 Re: tim in wi in reply to tim in wi, 09-28-2004 04:09:29
So the gas o ring is my target problem here? Interesting you had to replace it that many times in a 5 year period. Was that the same engine used on the Trailfires? From what I have learned it may be better that this o ring is the problem rather than the reeds because of secondary damage they cause. It does have compression on both cylinders so that is probably not the problem. I am leaning toward looking into this o ring for now.
tim in wi
09-29-2004 04:26:44
 Re: tim in wi in reply to Farmer in the Dells (WI), 09-28-2004 08:50:30
ill look at work today tim
