Tractor Talk Discussion Forum
Rear axle lube on JD 1945 ( A)
David L. Graber
09-27-2004 16:18:05
What I need is info. on where to check to see if trans. & rear axle fluid is full or not & where to refill. I know where to drain. This is on a 1945 John Deere(A) SN #545022.
1945 A
09-28-2004 07:17:10
 Re: Rear axle lube on JD 1945 ( A) in reply to David L. Graber, 09-27-2004 16:18:05
The fill plug is the large pipe plug on the right of the housing, about 1/3-1/4 of the way up, facing the housing. I believe it"s 1 1/4" pipe plug. Mine has a square head on it. Just fill it until it won"t hold anymore....
Hope this helps....
