Tractor Talk Discussion Forum
Question on Farmall Carb
DL
09-27-2004 16:33:34
Yesterday I removed the carb from my Farmall 400, took it apart and threw it into the cleaner. Almost everything is going OK... In the lower casting (fuel bowl side) there seems to be a vent in the bottom of the "tube" that the air flows through. If you turn the casting upside down and look at it, there is an approx 1/2" diameter hole machined into the bottom of the carb. Then, it looks as if a "washer" was pressed into the hole in the casting... the hole in the center of the "washer" is only about 3/32" in diameter and it looks as if it may be holding some sort of packing in place. Question... is this a vent that should be left open?? If so, how does it not pull dusty (unfiltered air) into the intake? Should the "washer" be removed & packing replaced (or is the material inside the opening simply years of accumulated crud)? If it is a packing that needs to be replaced, any ideas where I can find suitable material... the kit I bought for the carb included only one packing, the one for the main adjustment screw. I definitely appreciate any help y'all might be able to offer!!!
Regards, DL
Dave F.
09-28-2004 10:05:08
 Re: Question on Farmall Carb in reply to DL, 09-27-2004 16:33:34
DL, I think you could remove it, to clean the carb. and reuse it. Its a little felt filter.( probably hard with age) it's used as a drain if you over choke the carb the excess gas drains off through this hole. hope this helps Dave F.
DL
09-28-2004 11:58:07
 Re: Question on Farmall Carb in reply to Dave F., 09-28-2004 10:05:08
Hey Dave,
Thanks a million for your reply... your answer makes sense... guess you would need somewhere for the fuel to go! I'll pry the cover out to clean the bore, and if necessary, I can cut a new piece of felt to put back... I'm sure the missus has something like that in her sewing stuff. I'll just have to find it while she's at work!
Regards, DL
