Tractor Talk Discussion Forum
Massey 102
Dale Smilar
09-29-2004 16:27:09
Can Anyone Tell Me The Year Of My Tractor The Serial Number Tag Says"102js S/N 382261 I Have Double Checked This Info A Couple Of Times And Am Still Confused Any Help Would Be Appreciated
Alberta Mike
09-30-2004 06:01:48
 Re: Massey 102 in reply to Dale Smilar, 09-29-2004 16:27:09
Here's the rest of the story. First, you have a '44' 102 Junior Standard. The reason you number doesn't show up as a 102 is as follows. Originally when the 101/102's came out in '39, the 101's were the gas versions and the 102's were the distillate (low grade fuel) version. Sometime about 1943 or so (when Massey made several changes in the Junior lineup like grille, sidepanels, air cleaner location, etc) the gas Junior tractors exported to Canada were ALL tagged as 102's. I don't think distillate 102's showed up in Canada after those changeovers. I think the serial number lists stayed as 101's where your number shows up so your number shows up as a 101 on my list here.
Dale Smilar
09-30-2004 11:04:55
 Re: Massey 102 in reply to Alberta Mike, 09-30-2004 06:01:48
Thanks For The Info Alberta Mike That Sure Clears Alot Up .Now Do You Know Of Anyone That Has Tires For This Tractor Or Any Other Misc.Parts.Thank You
Alberta Mike
09-30-2004 11:49:57
 Re: Massey 102 in reply to Dale Smilar, 09-30-2004 11:04:55
Good used tires (28" I think they were) are not easy to find. I found some by advertising in the Bargain Finder but it's hard to find a pair, easier to find only one sometimes. Problem is when you find one good deal you have trouble matching the same make, tread, etc. when looking for another one. I have removed the hide feature from my email address if you want to contact me directly. What sorts of parts are you after?
Alberta Mike
09-29-2004 19:59:39
You have a 102 Junior, standard (non adjustable wide) front axle? I'm guessing you live in Canada right and your serial number says it's a 101 Junior? If so, respond here and I'll give you the rest of the story (assuming my guess is correct).
Dale Smilar
09-29-2004 20:08:55
 Re: Massey 102 in reply to Alberta Mike, 09-29-2004 19:59:39
Thanks For The Reply .The Plate Says 102
Dale Smilar
09-29-2004 21:22:19
 Re: Massey 102 in reply to Dale Smilar, 09-29-2004 20:08:55
Yes I Am In Fort Mcmurray Alberta.I Will Post A Picture Of The Tractor And Serial Number Plate If You Give Your E-Mail Address.
