Tractor Talk Discussion Forum
John deere 160 lawn tractor
Marc Weymouth
10-02-2004 07:56:34
I have a John Deere 160 Lawn Tractor that will start and idle fine but when you start to mow with it you get about a have a lap around the lawn and it stalls, then is hard to start again. I replaced the carberator but that didn't help.
UncleTom
10-02-2004 08:34:15
 Re: John deere 160 lawn tractor in reply to Marc Weymouth, 10-02-2004 07:56:34
Well when it quits it is loosing something. You have to find out what it is. Fuel, Spark, etc. If it has and igitnion module they are known for getting warm and lossing its spark. UncleTom
Christopher Hoffer
04-07-2005 07:37:19
 Re: John deere 160 lawn tractor in reply to UncleTom, 10-02-2004 08:34:15
I accidently disconnected a wire/switch which I belive is the kill switch for either the neutral gear or clutch?brake. The wire with a connector is located on the right side (if you are sitting in the seat) of the 160 tractor by the frame and is green. It is by the wire that leads to the seat kill switch. I can't find where to plug it into and the tractor won't start. Help please!
