Tractor Talk Discussion Forum
Help: MF-202 (MF-35) Hydraulic Lift Malfunction
George Holmes
10-05-2004 11:25:23
Gents,
The lift arms on my MF202 are stuck in the up position, and won't drop. Pump works constantly, no matter what. I have a pressure gauge installed on the upper right of trans housing,, reads 2,400 PSI, all the time, PTO on or not. No change in controls makes any difference. REmoved right hand inspection plate, moved control valve all the way forward and back, made no difference. surface of fluid was still. PTO was off. Turned PTO on, pressure briefly dropped, with clutch out, then pressure returned, hydraulic fluid began to spray out of the right hand inspection port, at the front edge, spraying vertically. Previously dropped the position control lever from "Fast" toward "response," didn't cause vertical levers to move toward control valve at all. I have purchased three manuals and a video, supposed to deal with this tractor, only the IT even touches on this system. Anybody able to help?
Thanks
Big Dean
10-05-2004 12:16:23
 Re: Help: MF-202 (MF-35) Hydraulic Lift Malfunctio in reply to George Holmes, 10-05-2004 11:25:23
Hi George the MF202 used two different three point lift control systems. [1] The early models has two vertical levers that hang down to contact the roller in the pump control lever. [2] The very late models had only one vertical lever hanging down to contact the roller in the pump control lever. These work a little different from each other. If you will E-mail with which type controls yours has I peobably will be able to help you with your problem.
