Tractor Talk Discussion Forum
6 volt battery charging
chez
10-05-2004 13:48:55
have a new 6 volt battery on the "h", wonder if i could use the 12 volt trickle charger i have to keep it .Tractor sits for long periods until used for the belt.thanks
FarmerDave
10-06-2004 06:48:57
 Re: 6 volt battery charging in reply to chez, 10-05-2004 13:48:55
Long time ago before I got my red ford running reliably the neighbor said I could jump start 6v from a 12 system. "It don't hurt em", he said.
BS or truth?
paul
10-06-2004 08:41:03
 Re: 6 volt battery charging in reply to FarmerDave, 10-06-2004 06:48:57
It doesn't hurt the starter. You can jump start the starter, directly to the starter.
If you get any other circuts involved, you can hurt that.
--->Paul
Lowell
10-05-2004 17:19:04
its best to put a timer on it to charge maybe an hour a day , even a trickle charger will boil the water out of your battery if it is left on charge constantly
JT
10-05-2004 17:00:00
Call me nuts, but we have a Schumacher battery charger that shows on one position being 6V-40A
12V-20A
don't know why, but it does, and when I charge a 6 volt battery, it does 'er.
Larry in CO
10-05-2004 15:51:22
chez,
Your best bet would be to go to your local Wal-Mart and pick up one of their trickle chargers. They cost around $19.00 and have a switch on them that allows you to maintain either a 6 or 12 volt battery. I have a couple of them and they work great.
HTH
Larry
Bob
10-05-2004 15:33:04
You CAN charge a 6 Volt battery with a 12 Volt charger, if needed.
Put a headlamp bulb in series with one of the leads for fast charge, or use a low-wattage dash light bulb for slow charging.
PASteve
10-05-2004 15:14:13
Using a 12V charge on a 6V battery will result in excessive charging current, cause a lot of the water in the battery to boil off and possibly damage the plates in the battery.
Leland
10-05-2004 14:45:02
I may be mistaken but a 12 volt chager will cook most 6v batts.
chez
10-06-2004 07:56:07
 Re: 6 volt battery charging in reply to Leland, 10-05-2004 14:45:02
thanks for info. went to store and bought a 6volt trickle charger
RayP(MI)
10-05-2004 17:00:05
Right, a 12volt charger will cook a 6v pattery if left on too long. Putting a bulb or other resistor in series will only prolong the process, when battery gets charged, and current drops thru bulb, then voltage across battery increases, and battery still cooks! Get a 6 volt charger/maintainer.
