Tractor Talk Discussion Forum
farmall 340 won't go
dangerdoc
10-07-2004 07:17:09
I backed the farmall out of the barn and put into 3rd gear, it wouldn"t budge. As I let the clutch out the engine bogs down. It does this in each gear including reverse. Even more strange, it does this in neutral also.
Any ideas?
dangerdoc
Dug
10-07-2004 21:23:41
 Re: farmall 340 won't go in reply to dangerdoc, 10-07-2004 07:17:09
Welp, first thing to do is sell that Farmall, then go buy a John Deere like your brother's.
Bob
10-07-2004 07:47:42
Your shift lever slipped out of the shift forks, leaving the transmission jammed in a couple of gears. You'll have to remove the tranny cover, line the slots in the shifters up in the neutral position, and carefully replace the cover, while making sure the lower end of the shift lever drops into the lined-up shifters.
