Tractor Talk Discussion Forum
Ford NAA steering
chris spellmire
10-10-2004 16:41:01
Trying to restore a 1952 or 1953 NAA tractor that my father and mother bought new in may, 1953. Got it running with some help from a neighbor. I have the original owner's manuel but need more info. The steering wheel rotates out of the column when you steer to the left. When you steer to the right it reseats itself and the tractor will steer to the right. I think something broke when my son yanked the old steering wheel off to replace with a better one. Is there a pin or bolt at the bottom of the rod that the steering wheel attaches to that may have sheered off? How do I fix it? Thanks!
Geo in SD
10-10-2004 18:41:35
 Re: Ford NAA steering in reply to chris spellmire, 10-10-2004 16:41:01
If I read your post right, it sounds like you have a bearing at the top of the steering shaft assembly that is broken. This bearing is the one that goes dry first, and gets rusted and pitted. Probably in the process of pulling the steering wheel, the bearing got broke up.
