Tractor Talk Discussion Forum
Surging Governor
Jason(PA)
10-11-2004 16:35:25
What actually causes a governor to surge? Weak spring? Im orking on a old Silver King right now and she wants to surge when it is at a idle. When its running around its ok and seems to be kicking in nicely. Any Ideas?? Thank You!!
MarkB_MI
10-12-2004 03:22:58
 Re: Surging Governor in reply to Jason(PA), 10-11-2004 16:35:25
A plugged carburetor idle circuit will cause surging. If the engine won't idle, this is the likely culprit. As others said, surging is rarely caused by the governor, it's just a sympton of some other problem.
Joe (Wa)
10-11-2004 23:04:46
Generally the problem is elsewhere and the governor is trying to compensate. Some governors have a droop adjustment to change sensitivity.
Joe
Jon H
10-11-2004 18:22:35
Depends on the governor type,but often lengethening the rod from governor to carb will eliminate surging.
Bernie in MA
10-11-2004 17:08:21
The Onan engine on my welder surges sometimes. Carburator adjustment will usually fix it.
