Tractor Talk Discussion Forum
Starting Fluid
FarmerDave
10-13-2004 07:06:27
My red ford ( gas ) has gotten hard to start lately. I have a lot going so I have not had a chance to look carefully for the root cause. But I have this can of starting fluid and it is pretty quick to use. Is starting fluid helpful? How much starting fluid is enough? How long does the squirt last? Like if I crank for twenty seconds and nothing happens I am apt to give it a rest. Then crank again in a minute.
BTW
Yesterday I cranked a lot. I though I would kill the battery before it would start. So I put the magnetic heater on the oil pan. I waited thirty minutes. I gave it a shot of juice. It started right up.
It starts better with out pulling the choke lever too.
Handyman
10-13-2004 19:42:50
 Re: Starting Fluid in reply to FarmerDave, 10-13-2004 07:06:27
try cleaning or replaceing your spark plugs they may be fouling out
FarmerDave
10-14-2004 06:07:17
 Re: Starting Fluid in reply to Handyman, 10-13-2004 19:42:50
I did that not long ago. They were carbon fouled.
I had this problem with the float not floating. My parts man says that the spring I had in there counteracting the bouyancy of the float was not supposed to be there. What he said was - I've never seen one there before.
I had black sludge forming on the lift arm too. Parts man said, and I forget which way, turn the idle screw in another turn. I did that, it helped.
The problem is one is supposed to adjust this carb by sound. Something like turn this in until the engine runs rough, and then back out half a turn. Unless you know what runs rough is supposed to sound like, how do you know?
One day somebody is going to record it and I'll be able to down load it as an mp3 or a .wav file. But I haven't seen it yet.
About five miles down gravel roads through the outback is a tractor repair shop. It's first come first served and your tractor has to sit out in the rain while waiting. But I think Albert may have to make the trip. Dad named him Albert.
Weirsdale George
10-13-2004 09:08:14
Sounds like you definitely have a fuel and/or carburation problem, especially when you mentioned the choke. Yes, the starting fluid will help, just make sure you aren't smoking at the time! (In a rare instance, it could be a weak spark, but here I doubt it.)
I would say the time length of spray should be something like two seconds. Works best when someone is spraying while the engine is being cranked. Also spraying directly into the carb throat works a lot better than spraying into the air cleaner inlet.
