Tractor Talk Discussion Forum
Farmall M
Iron Mike
10-13-2004 22:19:38
Just purchased an M. What weight oil for rearend?
When I drain the rearend will the transmission drain out also? If not what weight oil for transmission? What is the amount of oil the rearend and transmission hold? I also need to replace the air breather cap. Should I install the style with a jar or metal cap?
Richard Fazio
10-14-2004 06:05:18
 Re: Farmall M in reply to Iron Mike, 10-13-2004 22:19:38
Mike, The M has 13 "gallons" yes gallons in the rear. Use GL-1 90w. The engine is seperate. I forget how much it holds, something like 6 quarts of regular engine oil. I use 10W-40. After I drained and changed my rear end oil I got leaks from the axel seals and PTO. the oil was so low that it didn't leak any more. So now I just got done changing the seals. Jump over to the Farmall discussion forum at the left of this page under discussion Forums. You'll learn everything you need to know about your M.
Dr.Evil
10-14-2004 10:02:04
 Re: Farmall M in reply to Richard Fazio, 10-14-2004 06:05:18
H engine is six quarts, M is either 8 or 9. The BIG plug on the back of the M rearend below the PTO drains "Most" of the rearend. There's a little 3/8" plug on the front of a lower sump on the front of the rearend that drains the transmission, Plus some people play around with the belt pulley gear box if so equiped to get the half quart of old oil out of there. 4 or 6 bolts and it lifts right off but is heavy. Can put the 13 gallon of new 90W in thru there too.
