Tractor Talk Discussion Forum
1941 Case SC
markloff
10-14-2004 20:24:18
I'm not exactly a case expert so I thought I'd post and see if any of you are! I have the opportunity to buy a restored 1941 Case SC. This model has the exhaust going through the hood. It also has no ribs on the block and is refered to a "smooth block model" I believe. Can any of you tell me what it's worth and how rare it is. Any other details. I don't plan on keeping it I'll be reselling it. Thanks, Mark
Alberta Mike
10-15-2004 04:08:32
 Re: 1941 Case SC in reply to markloff, 10-14-2004 20:24:18
From a Case history book comes the following information.
The first S built was 4500001 on November 4, 1940. Early models had the smooth block (no ribs), fenders were deep dish style like early DC models, and the exhaust exited through the hood centerline as did the air cleaner stack. Hood sides were quite deep and lights were mounted on the fenders, one front facing and the other facing back. At # 4501149, the fuel tank bracket and battery cover were changed, the light bar was added under the hood with the lights moved there. A true tail light was added. The hood became a shallower sided model. Many light designs were used, the latest using a sealed beam. The last '40 was 4500789 on December 31/40. Changes in 1941 included the exhaust air stack to the outside at 4503029. Chrome strips on the tinwork were removed at 4600001 in 1942.Hope this helps.
dkasey
10-14-2004 23:24:21
Would suggest that you ask on the Case tractor talk forum. This is possibly a rare version of the 41 SC, but I don't know. Get the serial number and post it and see what the response is? Dollar value will depend on condition.
TimFL
10-14-2004 21:17:39
Does this tractor plan on voting for sKerry or Bush?
1941
10-14-2004 22:30:10
 Re: 1941 Case SC in reply to TimFL, 10-14-2004 21:17:39
It voted for Roosevelt
