Tractor Talk Discussion Forum
routing heated hose
benny
10-16-2004 08:15:26
help I have a 3020 with a hiniker cap i want to put a block heater on it and also hook up the cab heater its a 4 cyl. diesel i"m not sure of the routing heater hose anyone know the correct way thanks benny
I Bleed Green
10-16-2004 11:09:41
 Re: routing heated hose in reply to benny, 10-16-2004 08:15:26
I will tell you how i have them hooked up on my 4020 Gas. I have a Hiniker 900 cab.
I will start with the engine heater. The (cold) hose i have by the engine block drain. The (hot) hose should be in the head. I used the place where the bypass pipe connector goes into the head. I put a 5 or 6 inch nipple there with a tee at the top. I used a hose in place of the bypass pipe.
For the cab (cold) I put a nipple and tee by the radiator drain. For the (hot) i drilled and tapped (3/8" pipe tap) one of the thermostat housings. I think a 3020 only has 1 of them. A 4020 has 2.
