Tractor Talk Discussion Forum
Another Log Splitter Question
WiCraig
10-18-2004 15:27:42
Getting tired of putting up firewood the old fashion way, buying it. Tommorrow I will be looking at a 3 pt log splitter. It a "Danauser" model, will split up to 4' logs. Anyone know anything about this make, what to look for? good? bad? Seller stated that he paid $1500 for it 10 years ago and really never used it. Thanks, getting cold in Wisconsin.
Midwest redneck
10-19-2004 02:33:26
 Re: Another Log Splitter Question in reply to WiCraig, 10-18-2004 15:27:42
I suggest trying it out with a log and make sure it doesnt leak too bad and that it really functions correctly, doesnt bind up, the cylinder rod isnt bend etc. Good Luck, I also burn wood in the winter here in Mich. My neighbor made a real nice tow behind splitter. I used it last year for about an hour and split 2 face cords fast, sure beats the old ax-sledge method....naaa I like getting the workout.
jdemaris
10-18-2004 18:27:44
I don't have a Danauser, but I do have a three point splitter and have also worked on quite a few. There are some pretty good ones around in the $500 price range (new). Biggest complaint I've experienced with them is the tractor's hydraulics being too slow to run them adequately. I bought one a while back from an old guy that was running his off his Ferguson 30. He paid $600 new for the splitter with the 4" diameter cylinder (that puts it in the med. - heavy duty range). It ran too slow, so he then had to buy a PTO hydraulic pump and hydraulic reservoir kit for the splitter and it THEN worked fine. That's the way I bought it. The PTO pump and reservoir cost him an extra $500. I bought the whole works for $400. If I was going to spend over a $1000, I'd just go to Tractor Suppy Co. and buy their largest splitter, self powered with a 12 horse engine, for $1400. One other complaint I've gotten is from using large tractors to run the splitters. Some of the big tractors are not very fuel-efficient running three-point splitters of the tractor's hydraulics. But, everything has plusses an minuses. It's nice not having an extra engine to keep running, but it's kind of pain hooking the splitter up and taking it off (and finding a place to stand it up) if it's a vertical. Make sure the splitter's control valve matches the tractor you are going to use it on (closed center or open center).
Indydirtfarmer
10-18-2004 15:50:31
I didn't even know they made a log splitter, but they make excellent products. If it works OK, you can't go wrong. John
