Tractor Talk Discussion Forum
John deere G wheel center stuck
Hkid
10-25-2004 19:56:23
Just traded for a John Deere G. Need to put a tire and rim on but can't get the wheel center off the hub. (It's turned so as to narrow the track.)Is there a secret?????
Loren-MN
10-26-2004 14:45:55
 Re: John deere G wheel center stuck in reply to Hkid, 10-25-2004 19:56:23
JKid
Lots of penetrating oil. Put a chain through one of the holes in the wheel, around one of the mounting bolts on the axle, and back through a hole opposite the first. Turn the wheel till the chain is tight. Back it off a little. Then with all you've got, or maybe with a buddy helping, spin that wheel as hard as you can tightening up the chain. May take several tries, but it will break loose.
leland
10-26-2004 18:48:56
 Re: John deere G wheel center stuck in reply to Loren-MN, 10-26-2004 14:45:55
Thats a good idea beats driving around lot and hoping wheel does not fall off.
Leland
10-25-2004 20:04:06
Lots of beating and pentrating oil maybe lots of heat and a lot of cussing. but I have always found it's easier with keyway turned to botton if your axle has one.
hkid
10-26-2004 14:05:34
 Re: John deere G wheel center stuck in reply to Leland, 10-25-2004 20:04:06
Thanks. Been using two hammers, oil. Heat is next. How fragile is the wheel center? Will cleaning and greasing help prevent the next one?
leland
10-26-2004 14:32:57
 Re: John deere G wheel center stuck in reply to hkid, 10-26-2004 14:05:34
Don't get to carried away with sledge I would anti seeze instead of grease if you can get wedges loose this will help.
