Tractor Talk Discussion Forum
Re: wood splitter
Kevin (FL)
11-05-2004 13:53:21
Dennis,
Log Splitter power requirements are greatly influenced by the type of wood being split. Any sized gas engine can be connected to that pump, but the question is--how much force will be needed to split the wood? We have either an 8 HP (might be a 10 HP) MacKissic, made in PA and it will stall the engine on certain live oak logs. For water or red oak it'll run right through. I would suggest that you get the largest engine you can find (10 HP or bigger) and set the relief valve high enough to split the wood you've cut and low enough to protect the splitter components (and you the operator). 6 HP would work on light work but you might find that it won't handle tough logs.
