Tractor Talk Discussion Forum
ford 841 wiring
rst
11-07-2004 08:26:19
I have an 841 diesel that I am restoring, but I cannot find out anything on the original wiring with the push button starter switch that is located beside the gear shift. It was wired through a key switch only when I got it, but I would like to put it back with the push button switch. Does anyone have a wiring diagram file that you could e-mail to me.
Thanks,
RT
Jim.UT
11-07-2004 11:56:29
 Re: ford 841 wiring in reply to rst, 11-07-2004 08:26:19
third party image
Here's a diagram from the Vintage Ford Tractor Resource. It's based on the diagram found on page 59 of the Ford factory shop manual for 12v diesel tractors.
john in la
11-07-2004 09:40:16
If it is wired to start with the key you have a car relay installed. The push button on the trans will not work with this relay.
You will need to get a new 4 post relay from Ford/NH to be able to use the starter button.
If you need a wiring diagram or in-depth help come on over to the FORD Board on this site and post your question so we can help you. This Tractor Talk board we are on moves to fast for in-depth help as the post gets lost because of so many post.
We need to know if you will be totally stock or if you are using a alternator. If we do not have a wiring diagram already made up for what you have we will draw one for you.
Here is one we have for a gas engine with a alternator to give you of a idea. We can change it to fit your needs.
Wiring diagram
