Tractor Talk Discussion Forum
Ford 8N question
Chelle Shocked
11-07-2004 17:36:49
I have an old Ford 8N tractor my granddad left me after he passed away and was wondering who I could ask to determine it"s age. can anyone help me? Thanks...
Gerald J.
11-08-2004 11:41:26
 Re: Ford 8N question in reply to Chelle Shocked, 11-07-2004 17:36:49
The 8 in the model number indicates its the model that came out in 1948. It was only made until 1952. The last year of production had a side distributor, the previous production had a front distributor, like the 9N (came out in 1939), the 2N (war time version came out in 1942), and the prewar flat head Ford V-8.
Its an 8N by that casting number. Other checks are that it has 4 speeds forward in the transmission, and when a front wheel hits a clod or curb the ball worm steering doesn't break your arm. The 9N and 2N had three speeds in the transmission and used bevel gears in the steering box so clods and curbs could break the driver's arm. Also the steering shafts out each side of the bevel gear box are in line where in the 8N they are separated vertically. I'm thinking that the steering arms are part of the shaft in the bevel steering box and separate for the 8N.
So depending on the distributor its either 1948 to 1951 or 1952. Now if you do find the serial number you can get some closer.
Gerald J.
Farmered
11-10-2004 05:22:18
 Re: Ford 8N question in reply to Gerald J., 11-08-2004 11:41:26
My '50 8N has a side distributor. See Bob's link to identifing your ford. ED
Bob - MI
11-08-2004 05:31:19
You should stroll over to the Ford 9n, 2n, 8n site. Lots of chatter over there and a great group of guys who love to help out. Some real characters too.
As atated before, the S/N you need to find is stamped on the side of the block on a flat section by the oil filter. They can be tough to read sometimes but it"s there. You may have to use a wire brush or something to clean the area up. When you get the number you can click on the left side of this page to get the numerical sequence by year of manufacture.
Welcome to the group.
Bob
11-07-2004 17:42:34
Check THIS out:
Chelle Shocked
11-07-2004 18:30:27
 Re: Ford 8N question in reply to Bob, 11-07-2004 17:42:34
I saw the site and I appreciate the info. However I was unable to find my model. The only serial # or anything i have found is under the seat on the transmission housing. It is 8N4024... Any ideas??
Bob
11-07-2004 18:48:02
 Re: Ford 8N question in reply to Chelle Shocked, 11-07-2004 18:30:27
The number you are seeing is a casting number. You need to look carefully at the engine block, where shown in the picture on the site I linked. This number stamped into the engine is the TRACTOR serial number (providing the engine block has never been swapped out). There may be layers of paint or rust over the weakly hand-stamped serial number, but it should be there.
Various castings on the tractor have date codes cast into them from when the castings were made. (Could be MONTHS before the tractor was built)
I believe there are often visble date codes under the castings that extend out to the LH and RH rear wheels (axle "trumpets"), and, if you are beneath the tractor, looking up, just ahead of the seat area, you will see a rectangular casting bolted to the bottom of the tractor. This is the hydraulic pump base, and it SHOULD have a date code on it. For more "date info", go to the "N" board and type "date codes" into the search box at the top of the page.
Chelle Shocked
11-07-2004 18:50:49
 Re: Ford 8N question in reply to Bob, 11-07-2004 18:48:02
I really appreciate the help..
