Tractor Talk Discussion Forum
Computer Glitch ... need help !!!
Alberta Mike
11-07-2004 18:51:52
Something happened to my computer that I need help with. For some reason, everything (on email and internet hookups) went "bigger" in print. Almost seems like it is in Safe Mode which happens when I shut it down improperly but it's not as fuzzy or grainy (but is a bit that way). I need to scroll across to read whole pages. Any idea as to what happened and how I can get it back the way it was (smaller with whole pages showing)?
Wi Criag
11-09-2004 15:49:40
 Re: Computer Glitch ... need help !!! in reply to Alberta Mike, 11-07-2004 18:51:52
I'm with Teej, go to View and change accordingly.
Jrry
11-08-2004 06:30:41
Mike, my home computer did that a couple years ago except the font was about ten times what it should be. I tried to change fonts in every program I could find and I had a couple of techies look at it. The fonts was so big that it was difficult to check anything. I ended up just getting a new computer. Wish I had an answer for you. Maybe one of the below suggustions will help. Good luck.
Teej
11-07-2004 23:13:37
Same thing happened to me not long ago.
If you're using Internet Explorer, go to View, and there is an option for text size. Change it to a smaller size until you find the one that is what it used to be.
Anthony
11-08-2004 13:17:55
 Re: Computer Glitch ... need help !!! in reply to Teej, 11-07-2004 23:13:37
If it is happening on all programs it probably means that the graphics resolution got changed, maybe by some program that was installed.
Go to START>SETTINGS>CONTROL PANEL>DISPLAY>SETTINGS and change the screen area back to 800 X 600 or 1024X 768, whatever looks good for you.
Jake from Jakes Corner
11-07-2004 19:31:36
Something like that happened to Hiram Dortmunder who use to live down track from me. In his case though, it was after he'd been a partying at the Pink Gopher over to Whitehorse. Nobody knows what happened but when he waked up everything looked about three time bigger than it was. He finally moved to one of them countries what name ends in "stan" I can't remember which one and became a pre-school teacher.
From Kansas
11-08-2004 04:32:25
 Re: Computer Glitch ... need help !!! in reply to Jake from Jakes Corner, 11-07-2004 19:31:36
To Jake from Jakes Corner, we pass thru your corner on the way to Alaska, plan to go again next summer. Will wave as we go by.
Festus Grimes
11-08-2004 02:39:49
I thought one of them pre-school kids was gonna beat me up when that happened to me.
Matt_In
11-07-2004 18:59:06
If you have a mouse with a wheel in the center hold the CTRL button and then move the wheel and the print should get bigger or smaller depending on what way you go. If you have Explorer go to view and then text size. Hope this helps.
RT
11-08-2004 11:51:14
 Re: Computer Glitch ... need help !!! in reply to Matt_In, 11-07-2004 18:59:06
Matt, I wished I knew that before I spent 2oo.oo on glasses. Now if some one could figure out how to do that to a shop manual I`d be happy. RT
sammy the RED
11-07-2004 20:58:22
That will depend on how you have your settings set for your mouse.
Weirsdale George
11-07-2004 20:37:55
That's cool. Where do you go to pick up tricks like this one? Is there a book or website or something?
RZ(WA)
11-07-2004 20:03:20
Whoa... Learn sumpin new every day. Thanks
Bob
11-07-2004 18:57:21
With no programs maximized (desktop visible), right click on an open area of the screen, away from any icons. Then left click on "properties", and choose "settings", and adjust your screen area.
