Tractor Talk Discussion Forum
Wheel weights, Allen, Mark
Jerry L/az
11-11-2004 13:31:28
I need some help understanding wheel weights I am working on a ford series 800 model 850 it had some two piece weights on the inside of the wheels took them off so I could clean up the wheels. no name on them only X77 does that mean 10x77=770lbs per weight? there are two on each side.I would like to put them back on but boy those things are monsters. Jer
Jim.UT
11-11-2004 15:26:12
 Re: Wheel weights, Allen, Mark in reply to Jerry L/az, 11-11-2004 13:31:28
I have two piece wheel weights on the inside of my front wheels (Ford 850). They weigh about 45 lbs per piece or 90 lbs per wheel. Are you talking about two piece weights on the rear wheels? The only rear wheel weights discussed in the Ford literature are the pie shaped segment weights that went on the outside of the wheel, 12 segments per wheel. Yours might be some aftermarket units. How do they mount? Are there holes in the wheel dishes that they bolt to?
Jerry L/az
11-11-2004 15:41:01
 Re: Wheel weights, Allen, Mark in reply to Jim.UT, 11-11-2004 15:26:12
yes they are for the rear wheels.6 long bolts going thru the weight, disc and the wheel. three bolts per segment. jer
Jim.UT
11-11-2004 15:54:49
 Re: Wheel weights, Allen, Mark in reply to Jerry L/az, 11-11-2004 15:41:01
Are your wheel discs pre-drilled for the weights or did someone torch or drill holes later? If they are pre-drilled that would indicate either that the weights are factory and I just don't know what I'm talking about (a very real possibility) or that the weights and discs were swapped from another tractor (newer Ford or perhaps a MF....just another WAG on my part).
jhill
11-11-2004 19:44:24
 Re: Wheel weights, Allen, Mark in reply to Jim.UT, 11-11-2004 15:54:49
I have seen that style weight. They are factory weights but listed as Industrial weights.
Jerry L/az
11-11-2004 17:05:44
the disc, wheel, and weight all share the same holes just like you bolt the disc to the wheel except you use a longer bolt and add the weight to the backside. Jer
