Tractor Talk Discussion Forum
Bleeding clutch HELP A.S.A.P.
Super Steve
11-13-2004 10:44:41
I ran the slave cylinder out of fluid today and refilled, but now i cant figure out how to bleed it. theres a bleeder screw under the tractor in front of the rear end but i dont know how to bleed it. Theres no pressure when i hold the pedal down and undo the screw. should there be? should the tractor being running or not? Please help as soon as possible. i need this tractor right now and cant afford it not working. thanx Steve
R. John Johnson
11-13-2004 19:25:47
 Re: Bleeding clutch HELP A.S.A.P. in reply to Super Steve, 11-13-2004 10:44:41
Steve.
I don"t know if it is similar to a JD 2755, but this is how the clutch is bled on that tractor.
Fill the reservior. Just below is a fitting that looks like a grease zerk. Run a piece of clear plastic tubing from the fitting into the fill opening on the reservior. Turn the fitting a few turns to open it. Press the clutch pedal to the floor and hold it there. Screw the fitting tight again and release the clutch pedal. Repeat until the fluid in the tubing is free of bubbles.
On the 2755 you must be VERY careful which DOT brake fluid you use. The wrong type will destroy the seals of the slave cylinder and you will have to spilt the tractor to change it
Hope this helps.
John
Kraig
11-13-2004 14:59:07
On truck brakes I attach a small rubber hose on the bleeder, submerse the other end in fluid and have someone pump the pedal, you can hear the air come out, I have messed with pumping them up and opening the bleeder alot and this way worked awesome, you might want to pump it up and bleed it the usual way in the end once or twice but for the majority of the air do it this way.
Nor. Al.
11-13-2004 14:05:06
Don't know how it will work on your particular tractor but when I reworked car brakes I would leave fill cap off and slowy ease pedal up and down you will be surprised how much air will bubble out, go slow or you will blow fluid all over the place.
Allan in NE
11-13-2004 11:00:56
Steve,
Don't know anything about your particular rig, but I usually bleed a clutch cylinder with the use of a "clutch bleeding tool" from NAPA, which will push the fluid in thru that bottom bleed screw and fills the system 'backwards'.
Otherwise you spend half a lifetime tryin' to get the darned air out of it.
Tryin' to help,
Allan
Super Steve
11-13-2004 11:20:15
 Re: Bleeding clutch HELP A.S.A.P. in reply to Allan in NE, 11-13-2004 11:00:56
OK thanx Allan ill go get one of those then. do u know how much one is? Steve
Allan in NE
11-13-2004 11:52:22
 Re: Bleeding clutch HELP A.S.A.P. in reply to Super Steve, 11-13-2004 11:20:15
Steve,
Been a number of years since I bought mine; think it was like $39 or something like that.
Now that I'm trying to remember, hope that it was NAPA; might have been the Snap-On salesman. At any rate, NAPA should have it also. Tell them you are trying to bleed a hydraulic clutch and they'll know what you are talking about.
It comes with a small reserviour for the fluid and an assortment of ends. It's a little hand operated "pump-like" gizmo.
Fill that cylinder from the bottom up and your problems are over ('cept for where did the fluid go to start with?) :>)
Allan
Super Steve
11-13-2004 14:23:40
 Re: Bleeding clutch HELP A.S.A.P. in reply to Allan in NE, 11-13-2004 11:52:22
Allan we looked around to find the bleeding kit but couldnt find one so we made one out of a drill operated pump and some hoses. the only problems is we cant find the bleeder screw. i was wrong the one i thought was the clutch was actually the "driverside" brake. If anyone knows where to bleed a clutch on a 2100 leyland please let me know. we need this tractor and we are now a day behind in our work and the snows coming. Thanx Steve
Jerry Cent. Mi.
11-14-2004 12:10:42
 Re: Bleeding clutch HELP A.S.A.P. in reply to Super Steve, 11-13-2004 14:23:40
Remember to close the bleeder screw between pumps or air will just return when you lift the pedel. Open screw and depress the pedel. close screw and lift pedel. Repeat until the air is gone.
Super Steve
11-13-2004 10:46:48
forgot to mention that the tractor is a 2100 leyland if that matters
