Tractor Talk Discussion Forum
source for flat belts?
Lynn Kasdorf
11-15-2004 11:00:19
Is anybody making large flat belts, like to drive a thresher from the pulley on the side of our old tractors? Or do you just buy old ones?
Perhaps the Acme Flat Belt and Buggy Whip company...
JT
11-16-2004 06:55:13
 Re: source for flat belts? in reply to Lynn Kasdorf, 11-15-2004 11:00:19
Hit N Miss enterprises in Ohio has a good supply of belting and the old style lacer or aligator clips. The belts they sell are good belts, not the plastic ones you find in farm stores or such. That is their business. Old engines, parts and supplies. Web sight is:
www.hitnmiss.com
george md
11-15-2004 18:13:28
Lynn,
When I need flat belting for a lathe, mill,
drill press, or planer I go to baltimore belting.
Not too expensive for small belts but I don't
know how much for large ones . They are on 25th
st in the heart of the dark section .
george
Gerald J.
11-15-2004 16:28:13
McMaster-Carr industrial supply (www.mcmaster.com) has flat belts in urethane, rubber, and leather. And they have Alligator Transmission belt lacing sets. Be sure to be sitting when you look at the prices for leather belts.
Gerald J.
Leland
11-15-2004 14:37:22
I just happen to have a I belive a 35-40 footer for sale that is in good shape .Father liked to buzz wood with it if your interested let me know.
SB in AR
11-15-2004 14:12:56
Try your local bearing and power transmission store. Like Motion Ind. or Applied Ind. Tech. Those are the two largest. Although if you have a locally owned distributor, they'll probably be a little more willing to help you on an item like that. They should be able to order it for you. If you don't have any luck email me, and I give our supplier a call.
Steve Brown
Jonesboro Bearing
Jonesboro, AR
SB in AR
11-15-2004 14:18:42
 Re: source for flat belts? in reply to SB in AR, 11-15-2004 14:12:56
Ooops. Forgot to unhide my email.
Rod (NH)
11-15-2004 12:37:20
Hi Lynn,
Try here.
third party image Rod
James in NC
11-15-2004 11:45:29
Your local round baler dealer can make you a new one or they might have some used that will work.
txblu
11-15-2004 11:44:29
ex-cel on the www does baler belts. Whether or not they do closed flat belts, dunno. Askin wouldn't hurt. Ask them about their alligator fastner for joining the belt.
Mark
Jerry Cent. Mi.
11-15-2004 15:41:36
 Re: source for flat belts? in reply to txblu, 11-15-2004 11:44:29
I beleive that Tractor Supply can make some sizes.
txblu
11-15-2004 17:41:41
 Re: source for flat belts? in reply to Jerry Cent. Mi., 11-15-2004 15:41:36
Could be. But they sell a variety of things. Ex-cel sells belting. Whom would you trust to build your house. A hamburger flipper, or a mason?
Mark
