Tractor Talk Discussion Forum
Ram cylinder
Val
11-16-2004 17:01:00
Does anybody know where to get design information on Ram (rod displacement)hydraulic cylinder or any good book or sites for this subject ?
Val
11-17-2004 08:28:44
 Re: Ram cylinder in reply to Val, 11-16-2004 17:01:00
Thank you, all.
What I am looking for is correlation between cylinder bore size and rod Dia. without piston. I would like to replace single acting cylinder, 1.50 bore (25,000/year)
with hydraulic Ram (rod displacement cylinder), assuming potential cost savings due to design simplification. Is any special seals and wear rings are required ?
NC Wayne
11-16-2004 20:44:37
You might tey Bailey Hydraulics, and I believe Mcmaster-Carr, Grainger, and MSC all carry it, but what you need is a little book called the Hydraulics Handbook. It has charts for cylinder forces at different pressures, fluid flow through orifices, tubing, etc., as well as formulas to figure out just about anything hydraulic or pneumatic related you might want to do short of hiring an engineer. I believe it's still only like a dollar or two so it's money very well spent for the amount of info it provides.
Hermit
11-16-2004 18:08:45
Here's a website with engineering and design data for all kinds of projects including hydraulic design. Hope it helps.
http://www.engineersedge.com/Design_Data.shtml
George G
11-16-2004 17:20:03
Don't know all what you are looking for. But, here's something.
