Tractor Talk Discussion Forum
Hydraulic Ram
Val
11-17-2004 08:32:04
Thank you, all.
What I am looking for is correlation between cylinder bore size and rod Dia. without piston. I would like to replace single acting cylinder, 1.50 bore (25,000/year)
with hydraulic Ram (rod displacement cylinder), assuming potential cost savings due to design simplification. Is any special seals and wear rings are required
david val
11-18-2004 03:32:36
 Re: Hydraulic Ram in reply to Val, 11-17-2004 08:32:04
the single acting cylinder is probably extracting, if so rod diameter has no significance. the ram rod diameter should equal the bore diameter to get the same force.
david
Farmered
11-17-2004 18:16:33
Hydraulic ram? Isn't that where steel wool comes from? LOL
Hermit
11-17-2004 11:53:21
I forgot to mention to make sure there's a stop plate bolted to the fluid end of rod. If not, the rod will pop right out when it reaches the end of the shoulder (learned from experience).
Hermit
11-17-2004 11:39:43
I don't know if there's a formula for bore/rod correlation since the resulting force depends on the rod diameter and fluid pressure. The rod stability relies on the shoulder length and clearance not cylinder bore. Last year I changed the seals in my New Idea/Horn loader which has the ram type actuator. I took the measurements while it was apart.
Rod diameter - 2.344"
Shoulder diameter - 2.353"
Shoulder length - 5.25"
Cylinder diameter - 2.75"
I got the seals from NAPA's on-hand stock and they hold fine. There's also a non-pressure weather seal on the outside end of the shoulder just to keep the elements out. Hope this helps.
