How old am I?
JJ
04-24-1999 15:23:08
Bought a 641 Ford S/N 8570-JG rebuilt in 1970. Where is the site that shows the tractor's original age and other info based on the serial number? Thanx!
Donna Kennedy
07-26-2005 08:54:11
 Re: How old am I? in reply to JJ, 04-24-1999 15:23:08
What year is my tractor?
It is a 574 International.
What would the serial number be? if any?
Harold H
04-24-1999 17:44:16
JJ,
I don't know where Ford serial numbers are on the net but your tractor is a 1957 standard tread. You don't say if it is gas or diesel. The gasoline engine is a 3.4375 x 3.60 134 cu in rated rpm 2200 belt, 2000 drawbar. It tested 29.82 db hp and 33.65 belt hp. The diesel is a 3.562 x 3.60 144 cu in rated rpm 2200 belt, 2000 drawbar. It tested 29.33 db hp and 31.78 belt hp.It was standard with 5.50 x 16 front and 12.4 x 28 rear tires. Shipping weight was 2838 lbs gasoline and 3014 lbs diesel.
Harold H
JJ
04-24-1999 19:21:34
 Re: Re: How old am I? in reply to Harold H, 04-24-1999 17:44:16
Thanx Harold; you're a great time-saver. By the way, I got the gasoline version; not many diesels for sale in Central Louisiana.
JJ
