Tractor Talk Discussion Forum
OT - Dodge truck
Jim.UT
11-18-2004 16:53:01
I currently have a '98 Dodge Ram 2500 gas 2WD and am looking to upgrade to a dually diesel. I can't afford new so I'm shopping used. Today I found a '96 Dodge Ram 3500 dually ext cab 4x4 with 50K on the odometer. It seems really tight and well maintained. I wondered if anyone knows of any specific problem areas with the '96 Dodge? This one has an automatic trans and is priced at $14,500.
champspa
11-19-2004 15:45:26
 Re: OT - Dodge truck in reply to Jim.UT, 11-18-2004 16:53:01
got one 96 dodge-cummins dually, auto, went 116k on the tranny before rebuild and an aftermarket torque converter from goerend. have 180k now and working great
champspa
11-19-2004 15:48:29
 Re: OT - Dodge truck in reply to champspa, 11-19-2004 15:45:26
I thought I would add that I tractor pull and my 450 carrys a lot. total weight of trailer and tractor is 14200
marlowe
11-18-2004 18:20:56
put a BIG trans. cooler on it the BIGGER the better BBBBIIIIIGGGG heat is what kills them. i have 285000 on mine but i got a BIG cooler about half my miles are pulling some thing. i had mine made by a radiator shop and is the same size as the radiator
Mark - IN.
11-18-2004 17:36:51
The only complaint I've ever had about them is the automatic transmissions. They just have always had a bad reputation for a good reason, they're weak. Mine are Cummins, and at 25K to the dealer for a rebuild after losing 2-5 after reletively light duty. I know of a firm that has 8 gassers, and when my '01 went, I asked them about theirs, and as I recall 1/2 of theirs had the same problem.
But then again, I know a guy that has a two wheel drive cummins dually, and after his went, he went after market, and beats it into the ground like running a dragstrip (with trailers), no problem. Ran into a guy a month or so ago while fueling mine on the interstate, and his was an '03 or '04 3rd generation Cummins, automatic, dually, 4x4, and he says 100K on it pulling trailers from NY to CA, no problems.
As for paying $14K for yours, some will say too much. I say if is in good shape, go for it. Probably has a 10 year/100K drivetrain warranty still? My '01 still is covered, '96 has 200K and drive it daily. One tranny problem each, fixed, ok after, so far.
Mark.
Ray,IN
11-18-2004 20:24:00
 Re: OT - Dodge truck in reply to Mark - IN., 11-18-2004 17:36:51
The gas powered 1996 trucks do not have the torque of the Cummins diesel and are not as hard on the AT. The only problem is allowing the AT to "Hunt" for the proper gear when towing a heavy load. This creates tremendous heat very quickly, and of course destroys the AT. Dodge recommends locking out OD when towing at 55mph or below to reduce this risk of frying your AT. If the truck gets a slight shudder when accelerating with a load, the torque convertor is slipping and if allowed to continue will ruin everything with metal shavings from the convertor. The solution is a HD convertor and valve body, which eliminates AT problems assuming you don't overheat it. To learn all about this go to: dieseltruckresourse.com
