Tractor Talk Discussion Forum
ENGINE CONVERSION
HUSKY
11-20-2004 16:25:17
I AM THINKING ABOUT PUTTING A CATERPILLAR ENGINE IN MY FORD 1986 F250 WHICH HAS A6.9 DIESEL CURRENTLY ANYBODY DONE THIS?
I KNOW THIS ISN'T THE RIGHT FORUM BUT I THOUGHT I ASK POSSIBLY CONSIDER CUMMINS ALTHOUGH I KNOW THEIR ARE MANY WEBSITES ON THIS, ANY SUGGESTIONS?
Rod F.
11-22-2004 08:39:13
 Re: ENGINE CONVERSION in reply to HUSKY, 11-20-2004 16:25:17
As stated below, the 3208 was not one of Cat's better ideas. The 6.9 you have is probably more reliable. A 3116 Cat might make an interesting swap or a 6BT5.9 cummins. I also know a guy that put a Hino engine in an F250. That was just a pure widow maker, but it worked good. If you decide to convert, I would love to hear the story after, and see some pics. Good luck.
Rod
Jon H
11-21-2004 20:59:10
I had the chance to look at a 3/4 or 1 ton Ford with a 3208 cat in it. This was a manual trans model without AC. The engine compartment was very very full. No idea how well it worked, or how the front end carried that engine. I suspect the little 5.9 Cummins would be a more parctical swap.
Bob
11-20-2004 17:42:34
What CAT engine were you thinking of? I believe CAT bought Perkins, and many of CAT'S smaller engines are now Perkins. It certainly could be done, but I'd imagine Cummins engines into Fords are more common. Have you checked out:
http://www.fordcummins.com/
husky
11-21-2004 07:23:48
 Re: ENGINE CONVERSION in reply to Bob, 11-20-2004 17:42:34
CAT 3208 IS WHAT I WAS THINKING ??? YES I CHECKED OUT FORD CUMMINS .COM BUT FOUND IT QUITE$$$$$$ AND LEFT MANY OPEN QUESTIONS AND THEY WOULD NOT REPLY BACK I WANT TO PLACE THIS IN MY FORD F 250 4X4 W /AUTO TRANSMISSION C-6 6.9 DIESEL ENGINE ANYBODY DONE THIS W/CUMMINS OR CAT ANY HELP APPRICIATED THANK YOU FOR YOUR RESPONSEWHAT IS NEEDED FOR THIS CONVERSION ???? TRANS ADAPTERS AVAILABLE?????
Ron Anderson
11-21-2004 11:25:15
 Re: ENGINE CONVERSION in reply to husky, 11-21-2004 07:23:48
The 3208 is a bottom line engine from Cat. That engine has been used in several applications ranging from White four wheel drive tractors to light trucks, From what we have seen they don't last more then 2500 hours then must be rebuilt. They were nick-named sewing machine engines by Cat mechanics. No lugging power, etc.just didn't live up to Cat's reputation.
HUSKY
11-25-2004 14:23:46
 Re: ENGINE CONVERSION in reply to Ron Anderson, 11-21-2004 11:25:15
THIS IS WHAT I SUSPECTED THAT THEY WERE NOT LONG FOR THIS WORLD BUT I FOUND ONE FOR $1700.00 AND THOUGHT I WOULD ASK IF ANYONE HAD EXPERIANCE WITH THEM I APPRICIATE ALL THE INPUT AND WILL CONTINUE TO CHECK INTO CUMMINS ANYBODY HAVE ANY EXPERIANCE W/ THEM??? CONVERSIONS ???? good or bad THANK YOU
