Tractor Talk Discussion Forum
8n oil pressure
MNmrs
11-21-2004 13:44:58
My 52 8n has not been used for six months. Yesterday when it started there was no oil pressure. The last time it was used it had 40 lbs oil pressure. Any one have any ideas on what to do?
lucass
11-22-2004 10:02:25
 Re: 8n oil pressure in reply to MNmrs, 11-21-2004 13:44:58
on some rebuilds i put a little air pressure in the crankcase while cranking with the coil wire off to get it primed..i remember how hard it used to be to get oil pressure up on the old chevy vega after an overhaul and the air trick allways worked... lucas
Dave_N_Ga
11-21-2004 16:44:33
You probably need to reprime your oil pump. On the front of the motor above the water pump to the right there a 13/16 plug (I think it's 13/16). Remove it, pull out the spring and relief valve, fill with oil, and reassemble. That should bring the pressure back.
Dave
Nebraska Cowman
11-21-2004 15:00:04
was it below freezing? a chance you could have had frozen water in the pump and twisted the shaft off?
RAB
11-21-2004 23:37:25
 Re: 8n oil pressure in reply to Nebraska Cowman, 11-21-2004 15:00:04
Another option was the oil was below it"s "pour point" temperature and would not flow.
Regards, RAB
