Tractor Talk Discussion Forum
Nitrogen in tires?
Rauville
11-22-2004 04:26:32
Just had new front tractor tires mounted, and the tire shop asked if I wanted to use Nitrogen or Air. When I asked the advantage of Nitrogen...they replied: "It's just a lot better for the rubber".
I know it's a inert gas, and not subject to heat expansion, but is it really "better for the rubber"?
By the way, I went with old fashioned air...I still have some of that on hand.
JeffE
11-23-2004 05:07:51
 Re: Nitrogen in tires? in reply to Rauville, 11-22-2004 04:26:32
Main benefit is elimination of oxygen which causes rust on the rims and degrades rubber. Benefit inside a tire to the rubber is minimal because worst enemy of rubber is UV light (sunshine) combined with oxygen - not much sunshine inside a tire. So main benefit would be reducing rusting of rim. Don't forget air is 78% nitrogen already so some of the other theories of difference in expansion, migration, etc. would provide minimal benefit of nitrogen vs. air.
Davis In SC
11-22-2004 18:11:28
I keep a bottle of Nitrogen with a regulator. hose & air chuck. Mighty handy to air up a slack tire or run the impact wrench. I have been using this tank for about a year, & it is down to about 200 PSI. One or 2 more tires, & I will swap it for a full one.
Leland
11-22-2004 16:51:13
Local Cat plant also fills the huge tires on there off road trucks and loaders with nitrogen, they claims it keeps tires cooler under heavier loads.
buickanddeere
11-22-2004 13:39:11
Nitrogen is used as it's the cheapest non toxic gas that doesn't support combustion inside an aircraft tire. It's cheap little bit of extra safety incase engine braking isn't available upon landing. And the brakes/tires have to absorb all the kenetic energy and convert it to heat. The tires may get hot enough to start burning inside if "air" is used. The outside of the tire will cooldown faster being out in the open. At speed the flames from surface friction heat will be blown out anyways The tire saftey plugs blow out too early if the tires begin to burn inside & steering control will lost . Even when filled with nitrogen and the tires get hot enough to blow thier plugs from heat/pressure. The excaping gas is inert and will provide a wee bit of flame supression/heat absorbsion.
Sloroll
11-22-2004 13:14:33
Nitrogen is much dryer than air and doesn't expand and contract as much with heat. Air can condense in an auto or airplane tire. The water formed can cause a ballancing problem for high speed tires such as that of jets. Ice can also block a stem causing a leaky valve. Nitrogen doesn't seem to find its way out of a tube quite like O2 either. An O2 tube will eventually lose air. Good year has a new rubber tube called an Air Stop tube which virtually aleviates this problem.
720Deere
11-22-2004 12:01:26
I don't know of any advantages for use in tires, but it is my understanding that nitrogen is used by nascar teams to power air tools because of higher tank volumes. I know that I do not have all of the facts here, but I believe that I understand the principle.
Supposedly, much higher volumes of nitrogen can be compressed into a storage tank than plain old air. Nascar teams run their guns off of storage tanks, no live compressors involved. Have you ever seen the air tanks for off-roading? One tank of nitrogen will inflate several large tires where a regular air tank of higher capacity would only inflate 1 tire if you were lucky.
Like I said before, I don't have the science to back any of it up, but this is how I understand it.
Bob/Ont
11-22-2004 08:49:41
I think it's to reduce the chance of tire explosion.
Later Bob
Ludwig
11-22-2004 08:30:31
I dunno but the local tire place here charges like $5 to put in nitrogen but then warrentys it for the life of the tires. Meaning that every time you get a low tire you can bring it in for a free fillup. One of my friends went for it when he bought new tires for his pickup. He drives a heck of alot so it'll be interesting to see how it works out.
billyiron
11-22-2004 06:45:43
I guess it depends on how much you want your tires to grow,,maybe you could buy 15-5-38,s and end up with 18-4 46,s----- if you get a flat you better fix it right away, or the weeds will grow fast around it,, billyiron
Vern-MI
11-22-2004 04:57:40
PROS:
Using nitrogen instead of compressed air has distinct advantages, which lead to immediate benefits.
It has more mass, so it migrates through the tire three to four times slower. The result: Tires hold their psi longer.
It runs about 20% cooler. Less heat results in less tire degradation.
It drastically reduces oxidation on the rim and inner-liner (nitrogen systems almost totally eliminate oxygen -- the cause of oxidation -- from the mix).
It is environmentally safe.
CONS:
Look for the CTE's (Coefficient of Thermal Expansion) for N2 and regular air, and Thermal Conductivity properties. There won't be much difference, as air is ~78% nitrogen anyway.
The Diatomic Radii of N2 & O2
* N2 = 1.4 Å
* O2 = 1.32 Å
So... Diatomic Nitrogen is 0.08 angstroms larger than O2. And again... air is only ~21% Oxygen. Therefore, the migration theory really doesn't seem to hold much water.
Nitrogen - Atomic Mass 14 vs Oxygen - Atomic Mass 16
So where does the Nitrogen get more mass??
How is Nitrogen on the inside of the tire (which is relatively immune from wear) going to reduce Oxidation, when the exterior of the tire is exposed to the atmosphere (~21% Oxygen; ~78% Nitrogen)
RESULT:
Anybodys guess!
Oh really?
11-22-2004 15:27:55
 Re: Nitrogen in tires? in reply to Vern-MI, 11-22-2004 04:57:40
"It is environmentally safe." ????? Then I certainly wouldn't any ordinary air escaping from my tire into the atmosphere.:)
Bob - MI
11-22-2004 05:40:28
Vern
Don"t know what you do for a living but this was one of the most impressive posts I have ever seen. I spent a lot of years representing a large aerospace casting manufacturer and we had our share of scientists and this one took me back in time.
Scary thing I found out when I was with those guys was that pretty soon I understood what they were talking about and I began to keep up with them.
Ah, the good old days..... ....
By the way, if racing didn"t use N2 they wouldn"t have a chance on selling it for street use. Marketing hype.
Gerald J.
11-22-2004 07:29:27
 Re: Nitrogen in tires? in reply to Bob - MI, 11-22-2004 05:40:28
This was argued last summer on the Vintage Airstream List. Where the available air source is wet, using dry nitrogen for tire inflation can lead to more predictable tire pressures as the tires heat and cool. That's because of the varying effects of water vapor pressure with temperature as more or less water goes to vapor or liquid.
Its easy for a community race pit air source to pump so much air during a race period to include considerable water. The rest of us do drain our air tanks occasionally to remove the water, hoping to prolong the tank life.
Gerald J.
Vern-MI
11-22-2004 06:36:22
Retired Ford transmission development engineer. Good company to work for as I got involved in many interesting projects. We had McDonald Douglas engineers come to work at Ford when MD was cutting back. They were amazed at the miscellaneous, various and sundry sciences and technology which the engineering and build of an automatic transmission involve.
The work took me to Indianapolis, Fairfax, Batavia, Livonia, and Sharonville plants. Good people at all the plants who are very interested in delivering a very satisfying product at a reasonable cost. The most interesting project was the development of a pressure control system which involved an H.P VXIc Chassis with two embedded controllers, Alphi closed loop controllers, Atchley servo valves and Dynisco pressure transducers. We could control transmission oil pressure from 0 to 300 PSI at temps from -40 to 300 ºF with rise times of 90 milliseconds and hit the target within 3PSI regardless of the change in compliance of the applied component. Digital data sampling and analysis is a science unto itself. Pressure control in a transmission is open loop and is accomplished with Varible Force Solenoid and Pulse Width Modulated valves. Shift scheduling is done with On / Off solenoid valves.
Also worked for Muskegon Piston Ring where Ford was the most demanding customer.
Now, speaking of Nitrogen in you tires, you wouldn't be interested in feul line magnets, swirl-a-gigs for your air intake, or some goo to put in your oil which will pop the seals off your valve stems the first time you start in cold weather would you? Sorry for the long post.
Bob - MI
11-22-2004 07:02:01
 Re: Nitrogen in tires? in reply to Vern-MI, 11-22-2004 06:36:22
I grew up in Muskegon and am speaking to you from there now. About 1.0 mile from the airport.
Pretty impressive list of accomplishments you have there. I too worked with McDonnell Douglas on many projects but I was a supplier to them selling titanium investment castings in a variety of alloys for standard and also advanced applications. I was at Howmet in Whitehall most of the time, you may know them as Misco.
I loved the guys at MD as they were really down to earth (no pun intended). They wanted to take calculated risks where it made sense to push current technology to a higher level. Yours truly was involved with some significant milestones on the F-18 E/F program, X-36 tailess research demostrator and C-17 heavylifter for MD. It was a great time to be in aerospace about 15 years ago.
Not many people know that some significant flight structures on new aircraft such as the V-22 Osprey and the F-22 Raptor are now titanium castings because of the work that we did with key customers up in Whitehall, Michigan.
Sorry for the rant but I thought you would enjoy the story.
Harley
11-22-2004 12:09:22
 Re: Nitrogen in tires? in reply to Bob - MI, 11-22-2004 07:02:01
Huh????? ????? ????? ????? ?
Allan in NE
11-22-2004 05:12:07
Vern,
Tryin' to read between the lines here. The latest and greatest version of snake oil? :>)
Allan
Vern-MI
11-22-2004 05:26:33
 Re: Nitrogen in tires? in reply to Allan in NE, 11-22-2004 05:12:07
You got it Allen.
If it increases profits then it's good for both the business and the customer right?
More of a state of mind than anything else.
Can I sell you a chromed induction tube and a special air filter unit which you can clean and put fresh oil on periodically? You never know when you will get your tractor up over 7000 RPM and need that extra air flow!
rustyfarmall
11-22-2004 06:03:07
 Re: Nitrogen in tires? in reply to Vern-MI, 11-22-2004 05:26:33
Maybe we should try filling the tractor tires with helium, that way we could all use economical compact pick-up trucks to haul our tractors to the shows.
Davis In SC
11-23-2004 10:06:53
 Re: Nitrogen in tires? in reply to rustyfarmall, 11-22-2004 06:03:07
I always heard that helium will migrate out of a tire in a short time, due to the tiny size of the molecules.... Seems it seeps through porosity of rubber.
Leslie
11-22-2004 21:16:23
Just a though, what is differance in weight between helium and air when it is compressed to say, 20 psi??
caseyc
11-22-2004 09:39:23
let me know how that works out for ya!
Edchainsaw
11-22-2004 14:02:18
 Re: Nitrogen in tires? in reply to caseyc, 11-22-2004 09:39:23
Honestly I would really like to know how Helium would work in tires.. most of the time we try to ballast tires down but If helium really works it would be great on a show tractor.
oh and I was really impressed with Verns posts Ihave not seen that stuff in the 20yrs since I graduated Engineering school.. and I kinda missed it.. sometimes cows just dont talk at your level you know that.
Airhead
11-22-2004 15:56:54
 Re: Nitrogen in tires? in reply to Edchainsaw, 11-22-2004 14:02:18
I believe helium was first tried in tires way back in the early days of tractor pulling. It seems that the front end of those ETDs was way too heavy, and those good ol' boys just couldn't get the weight transfer they wanted, so they filled the front tires with helium.
Ray,IN
11-22-2004 20:26:31
 Re: Nitrogen in tires? in reply to Airhead, 11-22-2004 15:56:54
I wonder if the announcement by tire manufacturers of a discard date now molded into the sidewall has anything to do with the air vs nitrogen thing? The state that 6 year old tires should be replaced regardless of tread wear; that tires deteriorate from the inside, not the outside. I read about it on MSNBC.COM
edchainsaw
11-23-2004 19:57:35
 Re: Nitrogen in tires? in reply to Ray,IN, 11-22-2004 20:26:31
You know if the air does not change often inside the tire then there is no way the deteriation is from the inside out. because the chemical reactions would us up all available ions and would be nutralized after a short time.
where as the outside of the tire is constantly in the same elements and would never run out of reactions..
