Tractor Talk Discussion Forum
Firing order Ford NAA
Ron from NJ
11-22-2004 13:46:51
Can anyone tell me which cylinder is the number one on a Ford NAA?
I have an I & T shop manual it tells me the firing order but doesn’t orient me which cylinder is number one Firewall or radiator?
alg
11-23-2004 14:04:22
 Re: Firing order Ford NAA in reply to Ron from NJ, 11-22-2004 13:46:51
Right behind the radiator.What part of jersey are you from???
RAB
11-22-2004 22:50:48
Usually adjacent to the timing gear.
Regards, RAB
Bob
11-22-2004 14:09:35
As with 99.9% of tractors, #1 is the FRONT cylinder, nearest the radiator.
I Like Case
11-22-2004 17:48:04
 Re: Firing order Ford NAA in reply to Bob, 11-22-2004 14:09:35
And if my memory serves me correctly, the other 0.1% would be the ETD.
I Like Case
11-22-2004 17:19:21
Bob
11-22-2004 17:51:47
 Re: Firing order Ford NAA in reply to I Like Case, 11-22-2004 17:19:21
A portion of the .1% would be Allis Chalmers "G's".
The motor is behind the driver, and #1 is the very REAR cylinder (which is also at the rear of the tractor).
Then there's the Deere 2 cylinders that have no #1, just LH, and RH!
