Tractor Talk Discussion Forum
help,broke bro in law's auger wagon
fred kobs
11-23-2004 17:29:20
was helping B.I.Law haul in and sheared something off above the gearbox on a Bradford 542?? The bolt that comes thru the auger shaft looks to be 5/8" or 3/4" and the input shaft is only @1" in dia. gearbox does turn the output shaft that goes thru into the auger so hoping didn't hurt nothin in there. anybody had one of these apart, I cant tell a thing with corn raining out on my head when you open the trap. thanks in advance. fred
Fred Kobs
11-25-2004 04:44:21
 Re: help,broke bro in law's auger wagon in reply to fred kobs, 11-23-2004 17:29:20
update:wound up there was a bearing GONE in the top of the 90degree gearbox upper seal had left some time ago. box full of nasty smelling goo. salvaged ring and pinion installed grease zert in lieu of 90wt packed all new brgs w/J.D. cornhead grease. got lucky and did all w/load still on wagon. shaft is splined into auger from lower side. amazing how much better things looked in the daylight. fred
paul
11-26-2004 13:47:53
 Re: help,broke bro in law's auger wagon in reply to Fred Kobs, 11-25-2004 04:44:21
Thanks for the update, I had nothing to add but was interested in the outcome. As good as can be hoped for! :)
--->Paul
fred kobs
11-23-2004 18:42:56
hi, allan i think that's what i did but i can't find where it is. the pto feeds a small gearbox that is a 90 degree design, has splined shaft into auger, auger shaft looks like 2+" dia, input shaft end that i can see is prob 1"...can't find where a shear bolt would reside. also cannot make out where the transition into the auger is made. guess i'll have to figger out how to get it onto the 8' wide scale at the elevator in am so I can see what went on. looks like there's supposed to be a break-away clutch of some sort B4 the gearbox but it is froze up. ANY input welcome, thanks. fred
Leland
11-24-2004 06:10:24
 Re: help,broke bro in law's auger wagon in reply to fred kobs, 11-23-2004 18:42:56
Been there done that we put small auger under it and put grain in wagon, easier than dragging to town, and besides any more with a full grain cart on road they will give you a over load ticket here you are only allowed 20,000 lbs per axle on any wagon.
Allan in NE
11-23-2004 18:20:19
Fred,
Sounds to me like you just sheared the drive pin.
Allan
