Tractor Talk Discussion Forum
Farmhand F11 problems
Charlie N.
11-26-2004 19:34:48
Farmhand F-11B on Oliver 88.
All working well for 4 years.
Yesterday as I was plowing snow and leveling, shaft on right lift cylinder dropped out of cup attachemnt on bracket
mounted to rear axle.
Got it replaced and it dropped and I replaced it several more times as I was working the snow.
Obviously some dynamic has changed in this loader to allow shaft to compress into cylindder
while working. Loader is designed with shaft simply going into cup on axle bracket. No pin or collar to keep it in cup. As I stare at the loader, I cannot see what ever kept main cylinder shaft from pulling out of cup. However, it seemed to work well fro 40+ years.
Anyone have idea what has worn or changed to allow cylinder to compress enough to let cylinder shaft pull out of cup?
ANy help appreciated. pu
Allan in NE
11-27-2004 05:34:18
 Re: Farmhand F11 problems in reply to Charlie N., 11-26-2004 19:34:48
Hi Charlie,
On a 'B' model, the ram is held into the cylinder head by a roll pin (#12 in this picture).
Parts Book gives it's size as 1/2" x 2-1/2". Original part # 16934.
Hope this helps,
Allan
third party image
Dug
11-27-2004 07:58:53
 Re: Farmhand F11 problems in reply to Allan in NE, 11-27-2004 05:34:18
Allan,
Great info! Haven't had a problem like the one described, but I'll be ready for it when it happens.
I greatly appreciate your contributions.
Dug, proud owner of an F11 on a JD 2510
Rauville
11-27-2004 15:59:44
 Re: Farmhand F11 problems in reply to Dug, 11-27-2004 07:58:53
Dug;
I've got the same setup (F11 / 2510). Good outfit, as long as you don't let the neighbors borrow it for trying to carry two round bales at once! I think if I look hard enough I can find the original sales receipt from 1973 for the loader which was priced about $1700 installed.
Dug
11-30-2004 22:17:51
 Re: Farmhand F11 problems in reply to Rauville, 11-27-2004 15:59:44
Hey Rauville,
Sounds like you've had yours awhile. I do like the set up, it has done everything I have ever asked it to do.
What types of toys do you have for the loader? I have a grabble and bucket. Can't seem to find many attachments around Kansas. Been told Farmhand was big out west and never really caught on here.
Post a pic if you get a chance, would love to see it.
Dug
Allan in NE
11-27-2004 08:07:33
Now, Darnit Dug!
Put your money where your mouth is. :>)
Go out and take a picture of your John with that F-11. I wanna see!!! :>)
These things are all over around here. On all kinds of tractors, reversed trucks & the like and mounted every which way imaginable. The horsey people like to use 'em to feed 'old snort' in the winter.
Allan
Charlie N.
11-27-2004 06:14:32
Allan: Thank You, this really helps. The diagram makes all sorts of good sense, exactly what I would logically expect. The other day clearing snow in WY,
and lifting the cylinder back in place, not easy by myself and no one at controls, I did not look close, but I believe the shaft was solid and no hole in the part # 19 shown in your diagram.
I will look again this morning. Also, I will check the model ans serial number tags again.
I may be back for more questions. I appreciate the help.
Allan in NE
11-27-2004 06:43:59
 Re: Farmhand F11 problems in reply to Charlie N., 11-27-2004 06:14:32
Charlie,
On the F-11C, Farmhand reversed those lift cylinders and they are of a somewhat different design.
However, the "cup" is about the same even though it is now on the front of the loader.
Here's a picture of that big roll pin on my "C" model.
What part of Wyoming? You must be right across the fence from me.
Allan
third party image
Charlie N.
11-27-2004 07:45:20
 Re: Farmhand F11 problems in reply to Allan in NE, 11-27-2004 06:43:59
Allan: Thank You for the picture. Just came in from shed. It is all exactly as you say for F11B. I will be looking for roll pin and repair should be easy. Model serial no. tag says F11B ser. 8947. Do you know of years of mfg of F11's? I will be looking for repair manual and parts manual. Do you have any ideas? North of Cheyenne. Which part of NE are you.
THey are warning of big storm coming tonight our area.
Thanks for the troupble and the help. THis site has been great help on the Oliver parts repais and your Farmhand help.
Charlie
Allan in NE
11-27-2004 07:53:54
 Re: Farmhand F11 problems in reply to Charlie N., 11-27-2004 07:45:20
Charlie,
I never paid any attention to the years that they were manufactured; I just like the old things is all. :>)
I have the F-11B manual and will scan it for you, if you like. There is not much to it; only 11 pages.
I live 10 miles south of Chadron out here in the Pine Ridge and the farms are down on the Flats.
Allan
Charlie N.
11-27-2004 20:22:01
 Re: Farmhand F11 problems in reply to Allan in NE, 11-27-2004 07:53:54
Allan: I would really appreciate the scanned manual.
How do we do this and how do I repay you.
Storm should be your way by now.
Had to go to Denver today somehow wifes christmas shopping with relative got more important than fixing the F-11. I believe her mind is changed as we got home to see the drifts and no loader. On the way home much snow and ice. Many wrecks. Had to stop and help one who rolled his Ford pickup right beside me.
It's all old stuff for me also. Built a new shed this year for a place to make repairs. The 88RC has been in our family (colo.) nearly since new. We use many 77's and 88's in hay grinding business with Hydraloaders. Bought this 88 when youngest uncle sold out the business my dad started. The F11 from a neighbors auction. Been a good pair. As I think back I can almost gaurentee when I broke the roll pin in hard dirt around the new sheed. Didn't know it until I needed it for snow and was scraping backwardstreching the loader out. Guess I'll learn.
Let me know how we can do the manual scan and send.
Thanks to you and all on the board for help
Charlie
Allan in NE
11-27-2004 07:58:43
Charlie,
That rollpin is generic and you should be able to find it at just about any parts outlet or implement dealer. Just take the measurements with you: 1/2" x 2-1/2".
Allan
Charlie N.
11-28-2004 15:17:19
 Re: Farmhand F11 problems in reply to Allan in NE, 11-27-2004 07:58:43
Allan: Got the F11 fixed and moved a few drifts today.
More drifts forming. THanks for the help Would really appreciate a scan of the manual amd a way to repay you. Let me know
Charlie
Fred OH
11-27-2004 14:01:33
Or just stick a half inch bolt thru it if the rollpin turns hard to find...if a hollow rollpin will hold it, a soft or medium hard bolt probably will too. Fred OH
