Tractor Talk Discussion Forum
VAS Tractor??
JH
11-28-2004 17:53:21
I found a tractor (Case VAS 5752202)I cant find any info on this model. I am a JD, Farmall, Ford, Allis Chalmers owner and would like to add a Case to the collection. Also this is a family tractor which I have none of. If anyone could give me some info on this tractor model it would be helpful. I am assuming it is a 1953 but cant find production numbers or years of production on the VAS.
Thanks,
Jeff
Nat
11-29-2004 13:13:50
 Re: VAS Tractor?? in reply to JH, 11-28-2004 17:53:21
A case VAS is a VA series set up for cultivating veggies. It is ofset like an A farmall and has a 4 cyl engine, 4 sp trans, live lift, trans. driven PTO. They are narrow and top heavy. It came out with the Eagle Claw hitch, though most have been converted to a 3 point hitch. Most parts from a VAC will interchange
Dlm
11-28-2004 19:05:07
Are you sure it is not a VAC
Jeff Holland
11-28-2004 19:54:14
 Re: VAS Tractor?? in reply to Dlm, 11-28-2004 19:05:07
yes positive -- while waiting for a response I did find that the VAS is a offset High Crop Version... I still dont know however what years it was made.
Dave_Id
11-29-2004 14:59:49
 Re: VAS Tractor?? in reply to Jeff Holland, 11-28-2004 19:54:14
If you have the ser. number, subtract 4 from the first two numbers, and that will give you the year if it is a seven digit number
