Tractor Talk Discussion Forum
howto remove overdrive clutch on 8n
willis porter
12-01-2004 06:14:26
t
ryed to remove override clutch to hookup plow
noluck
tlak
12-01-2004 08:48:30
 Re: how to remove overdrive clutch on 8n in reply to willis porter, 12-01-2004 06:14:26
Take out the grease zerk and plug . There should be a roll pin in there. Knock it out. You can get an ORC that has the spring loaded pin for quick removal
Jerry/MT
12-02-2004 19:00:01
 Re: how to remove overdrive clutch on 8n in reply to tlak, 12-01-2004 08:48:30
Do you know where to get an ORC that has a push button release? I haven't found one yet.
Fred OH
12-01-2004 08:43:36
 Re: howto remove overdrive clutch on 8n in reply to willis porter, 12-01-2004 06:14:26
Willis, remove the two zerk (grease)fittings and use a pin punch to drive out the 5/16" rollpin. You"ll have to turn it till the pin lines up with the hole. Fred OH
