Tractor Talk Discussion Forum
steering JD 3010
Henk.
12-01-2004 14:16:23
The steering on my 3010 JD is locked in the left turn position It doesn't move at all. When I shut the tractor off I can move it manualy by jacking up the tractor and move the wheels. But when I start the tractor it goes back to the left turn position. The dealer has rebuild the steering housing twice and it still won't work and now they have picked the tractor up and are trying to figure out how to fix it.
Do you know what it might be?
Bob
12-01-2004 15:41:03
 Re: steering JD 3010 in reply to Henk., 12-01-2004 14:16:23
You most likely have a damaged or miss-adjusted poppet valve in the steering control assembly at the base of the steering column.
There could be a bad "O" ring or a wierd thing such as a cracked casting, but the first scenario is the most likely.
