Tractor Talk Discussion Forum
Highest compression gas motor
550Doug
12-04-2004 18:56:39
Are there some gas motors with higher compression than others? What is the normal range of gasoline compression?
Thanks
RAB
12-05-2004 00:05:44
 Re: Highest compression gas motor in reply to 550Doug, 12-04-2004 18:56:39
I would think 6 to 10.5 would be the "normal" range for most motors.
Kero burners were lowest ratios, below 5, to prevent pinking, and pre lead-free engines with electronic sensing (that retards the ignition, on sensing detonation), were at the top end, as european car manufacturers went for smaller engines with higher compression rather than "cubes" like the american ones.
Of course, there are always those that say "what is gas?" and use that term for any special mixture of methyl, ethyl, or whatever, including water injection.
F1 cars all burn the same fuel because they used to have special formulations from their sponsors to up the octane rating, so the minions buying their product thought it was better than someone elses!
But there we are, even a diesel comp ratio would run on a gas engine quite nicely - at the summit of Everest!
Regards, RAB
Bob
12-04-2004 19:09:02
Are you talking compression ratio, or compression PRESSURE?
Some old engines are in the 4:1 compression ratio range, and probably will only have 40 - 60 pounds of compression, while exotic-fueled engines can have at leat 12:1 compression, and over 200 pounds of compression pressure.
And then, of course, there's the diesels, with 15:1 - 22:1 compression ratios, with 400 to 600 pounds of compression pressure.
JT
12-06-2004 07:13:19
 Re: Highest compression gas motor in reply to Bob, 12-04-2004 19:09:02
a lot of the naturally aspirated racing engines are running 12.5-13.5:1 compression ratio, but have to run 108-112 octane racing fuel. Most normal stock gas engines have a compression ratio of 6.5-8.5:1.
buickanddeere
12-05-2004 15:20:48
Plus those turbo and supercharged spark ignition and compression ignition engines have an even high "effective" compression ratio and combustion chamber pressures. You can get unleaded gasoline up to the 115-117 range with toulene and xelene (spelling?). Now add some lead and that's where the 145 military AV gas comes from. They even used water injection on top of that. The LS2 corvette and Pontiac GTO run about 10.9 to 1 on pump premium.
Ray,IN
12-05-2004 21:07:46
 Re: Highest compression gas motor in reply to buickanddeere, 12-05-2004 15:20:48
I once had a 1965 Olds 442(sure wish I had kept it). The 442 stood for: 4=400ci,4=4 speed, 2= dual exhaust. The engine had 13/1 compression from factory. That model was one of the big muscle cars of the era.
Ray,IN
12-05-2004 21:11:45
 Re: Highest compression gas motor in reply to Ray,IN, 12-05-2004 21:07:46
Now that wasn't right! It should read: 4=4 barrel carb, 4=4 speed, 2=dual exhaust. Hey- give me a break; that was a few years ago.
buickanddeere
12-07-2004 13:35:25
 Re: Highest compression gas motor in reply to Ray,IN, 12-05-2004 21:11:45
I'm not too certain about the 13 to 1 compression.
