Tractor Talk Discussion Forum
Ford truck not charging. OT.
DStout
06-21-2007 02:19:32
Morning fellows, need some help. I have a '91 Ford 3/4 ton 4x4 diesel. It stopped charging the batteries last week. Checked the alternator and found it was bad, replaced and still not charging. Checked voltage regulator on passenger inner fender well and replaced. Still not charging? Dumb question is there a 'master fuse' some where in the circut or some other little thing I'm missing? I can charge up the batteries and it will run a couple days on the two 1200 amp batteries but would like to get it to work right. Thanks for taking time to help me out.
David.
dboll
06-21-2007 09:21:46
 Re: Ford truck not charging. OT. in reply to DStout, 06-21-2007 02:19:32
I had the fusible link go bad after an alt. failure on my 92 F250
Don-Wi
06-21-2007 09:04:57
Can't help on the no-charge, but when I replaced the alt. on my 88 F150 I had to replace the harness that plugged into the alternator, came with the alt. at no charge- parts guy said it was because of as fire hazard with the old harnesses. Did you have to replace it or here anything about it?
Donovan from Wisconsin
Bob
06-21-2007 05:42:55
Check the fusible links coming from the battery cable side of the starter solenoid on the inside of the RH fender. One of those will be for the alternator.
frankiee
06-21-2007 05:20:42
Link
Looks to me like there is a condensor on the yellow/ white wire from the voltage regulator.
I would find this and remove it for testing purposes and see if it charges
I take it that the alt light is on.
DStout
06-21-2007 06:51:02
 Re: Ford truck not charging. OT. in reply to frankiee, 06-21-2007 05:20:42
Yep and amp gauge stays around 11-12ish and drops as batterys get weaker.
souNdguy
06-21-2007 11:02:16
 Re: Ford truck not charging. OT. in reply to DStout, 06-21-2007 06:51:02
I'd wager to be that's a voltmeter.. not an ammeter...
Soundguy
Allan In NE
06-21-2007 04:11:01
I had one of those donkers one time that just about drove me crazy, as I could throw parts at it all day long and it wouldn't help. :>)
Seems to me that there are two field wires at the alternator and that they can't be reversed?
Maybe somebody who works on 'em every day will jump in here.
Allan
Vern-MI
06-21-2007 03:43:57
I would get out the handy dandy VOM and check the output from the alternator. My suspicion would be that the replacement alternator isn't any better than the first. If the alternator checks OK the next thing I would look for is a bad ground from the engine to the chassis.
