Tractor Talk Discussion Forum
Massey Harris Serial Numer locations
Schultzy
12-08-2004 20:13:50
Hello,
I'm wondering if there's any way to find out the serial number of my Massey Harris 555 Diesel. The serial number tag is beaten and unreadable. Is there any other place it's located on the tractor?
Thanks,
Russ
Alberta Mike
12-09-2004 05:43:20
 Re: Massey Harris Serial Numer locations in reply to Schultzy, 12-08-2004 20:13:50
Not totally sure about a 555 but on all other earlier Masseys, it was hand-stamped into the upper machined surface of the transmission case between the cast iron shifting platform (supports shift lever) and the steel plate covering the differential gears. It's there on the left side near the location where the clutch pedal is when it's fully in the out position. The numbers are big but sometimes not too deep so you'll have to wire brush the area. As I said, I'm not totally sure about the triple-numbered Masseys. There are casting dates on the bottom of the Transmission/differential housing, those will give you a date when that casting was poured, probably pretty close to the tractor model year but not necessarily spot on.
Don Wadge
12-09-2004 05:35:50
Yes, it is stamped into the transmission case. I can't remember exactly where. It seems it might be on the flange where it bolts to the front belly section.
DERF
12-08-2004 21:13:27
Massey harris usually has the date code below the rear engine chassis cast.
TomTX
12-08-2004 20:26:33
Might want to post on the MF Board.
