Tractor Talk Discussion Forum
Snapping snowblower sheer Pins
Snow and lots o
12-09-2004 18:29:58
Sears snowblower has run good for eight years now I keep snapping Drive sheer pins like toohpics. I can't see anything out of aligment I am snapping 1\4 inc bolts plus a 1\4 inch nail Please I need help in seven days we got 3 1\2 ft of snow I'm notsuppose to shovel bad heart all help greatly appreciated Thank Patrick, MERRY XMASS
RayP(MI)
12-10-2004 15:52:32
 Re: Snapping snowblower sheer Pins in reply to Snow and lots of it, 12-09-2004 18:29:58
Be sure you're using the proper grade of bolt - If you're using a softer bolt, it will break prematurely. Also try using a self locking nuts, and be sure you tighten the nut snugly. Loose shear pins will shear!
JT
12-10-2004 07:13:41
As the others said, you probably have a loose hole in auger shaft. Try puting new bolts in and then tighten, really tight. If that does not help, as Willy said, drill a hole farther down the shaft, don't put it close to the other hole or you will weakin the shaft and then it will break in two.
Bob - MI
12-10-2004 06:11:45
I would agree with the trouble shooting suggested to determine if there is excessive drag somewhere.
After that however I am suspicious about a burr or some other issue in the shaft and coupling that the pin goes through. The pin is supposed to be the weakest link in the chain and sacrifice itself before the driveline gets all torn up. That means that the pin is made from a softer alloy that "shears" easier than the rest. If pins are being eaten up suddenly there must be something that is accelerating the coupling"s ability to slice the pin in two.
Pull the shaft/coupling apart and inspect the holes for burrs and/or elongation. If one of the holes is elongated it will cause the joint to rock back and forth and that will accelerate the shear. A new pin should fit closely in each of the holes. If it"s wobbly that part would be a candidate for rework/replacement. Worn shaft to coupling interface would allow too much slop also. I would look at that too. A burr in the hole will scar the pin as it passes through and it should be visible. I would not continue with the nails. They can make matters worse and defeat the safety intent of the pin and tear up the drive. I live in Michigan and can relate to how badly you need this running right now.
Best of luck
Willy-N
12-10-2004 06:49:49
 Re: Snapping snowblower sheer Pins in reply to Bob - MI, 12-10-2004 06:11:45
Good point my 12 hp walk behind snow blower I had blew a shear pin when I snaged a rock in the auger. It happen again real soon. The holes were elongated by doing that and it started cutting them all the time. The Auger could rock back in forth. I had to drill 2 new holes for them and the problem went away. Mark H.
Mark - IN.
12-09-2004 19:17:05
Could be for several reasons. I don't have a Sears snow blower, but have another type and have delt with sheer pins for a wide variety of other pieces of equipt.
Does your auger require lubrication (grease zerks) on the shaft ends/bearings/caps? Could be a burr or dry bearing surface working against you. Snapped a sheer pin, replacing with a bad supply/source? May want to try another supplier source, I would - what's the harm? Auger didn't hit something and is knocked out of balance? How's it rotating as you look at it? Look balanced, or does it vibrate and shimmy? Lot of snow? Not more heavy snow than is rated for, is it? Just a few possibilities.
Make sure is lubricated if can, try a different supplier (batch) of pins, try operating at in a lower gear if is self propelled, and higher RPM.
Sorry about the bad ticker, but is more of a reason to make that thing works for you. My brother's snow blower broke one, then began breaking (eating) the replacements like kids go through candy, for no apparent reason that either of us could see. He's convinced is getting bad supply and just quit using sheer pins altogether, and is extra careful not to chomp into things shouldn't - I wouldn't advise that, but works for him.
Good luck, Mark.
12-10-2004 19:48:54
 Re: Snapping snowblower sheer Pins in reply to Mark - IN., 12-09-2004 19:17:05
Thanks to everyone for your help. Yes I found the auger play slop hole is elonggated badly will drill a new hole and repin the auger Thanks Pat.
