Tractor Talk Discussion Forum
Liquid filled tires ????
Randall Higgins
12-10-2004 12:32:09
I discovered that the tractor I purchased a couple of days ago has had it's rear tires filled with some sort of non-freezing liquid ( glycol or something perhaps ?) .
I assume this is for added traction weight while using the front loader and such.
Is this a common and acceptable practice ?
What are the pros and cons ?
Thanks,
Randy
jim
12-11-2004 06:03:28
 Re: Liquid filled tires ???? in reply to Randall Higgins, 12-10-2004 12:32:09
You won't have a rust problem with cacl if you fill it just over the rim. You have to have air to rust. 1/2 full without tube, guarenteed a pile if rust. You can run less if you use a tube.
RAB
12-11-2004 02:42:33
Search the archives for"calcium" or other likely keywords on this and the other forums. When you have finished reading all those posts, you should be in a position to make up your own mind on the subject.
Regards, RAB
paul
12-10-2004 19:22:13
Well, you got a pretty good responce.
CC is not toxic - it's just salt. While it's hard on metal if you neglect it, the EPA doesn't come after you when it laks out....
Antifreeze concoctions are toxic, and any spill over a couple gallons is _supposed_ to be reported to the athourities - bad for the enviornment. Also it is lighter than water, while the CC is good weight at being heavier than water.
My coop would read me the riot act if I called them out for a repair & they pumped antifreeze out of my tires and contaminating their CC reserves.
For me from my tire coop, CC is far cheaper than antifreeze. Man,150 gallons of antifreeze per tractor? Yikes!
Rim guard seems like a good alternative if you don't like CC.
This is just my opinion on it, what ever works for others. CC is far & away the best choice - in my area.
A loader tractor needs weight on the back, and tires 3/4 fll of fluid (it needs an air pocket yet, should never be plumb full) is a real good start. For heavy use, you'll need a bit more, wheel weights maybe. Something hanging off the rear is very good, that acts like a teeter totter & picks a tiny bit of weight off the front end axle, which gets overloaded with a loader.
You just don't wantto run aloader without any weight on the rear of a tractor, it is very dangerous when you have a full bucket lifted up high.
For some tillage operations, you want the added traction as well. For others, it would be a waste tho...
--->Paul
720Deere
12-11-2004 07:17:59
 Re: Liquid filled tires ???? in reply to paul, 12-10-2004 19:22:13
Pure glycol antifreeze is heavier that pure water! If I remember correctly it is somewhere around 9 lbs per gallon. Liquid ballast is most definitely cheaper than iron ballast. Liquid will also put the weight to ground better. We learned that in antique tractor pulling. The liquid ballast pushes the tread into the ground where an air filled tire with the same amount of iron ballast will allow the tire lugs to flex and lose traction.
I don't have any love for CACL. I have never used Rimguard so I can't comment on it. If I was loading a set of tires, I would probably find some used antifreeze. Construction or trucking companies should have quite a surplus that they would be glad to give away. The only problem is if (when!)you have a flat, glycol is toxic and can create some issues for you. Rims with CACL will last 20 to 30 years or even longer if taken care of. Rimguard can be quite expensive enough so that replacing rims down the road could be worth the risk. Glycol is a toxic pollutant that could require extensive cleanup if leaked in quantity. As much as I hate it, I still believe that CACL may be the most economical long term solution.
wolfmantractor
12-10-2004 16:04:31
After about 40 -45 years, a rusted out rim around the valve hole happens. Tire guy will pump fluid into your barrel where it will sit a few days while machine shop will put a patch in rim & drill a new hole for valve stem. You then smooth it up with grinder and/or wire brush; paint with rust-o-lium . Mount tire, pump calcium back in & you're good for another 40 years. Of course about every 10 you will need a new valve core as soon as you see a little moisture around the valve. I thought all tractors had calcium cloride solution - then one day I saw one with air-filled tires! A 4440 and it couldn't hold back a silage wagon going down hill. Scary sight as it jacknifed down the lane. Rusted rims kind of go with the territory.
Allan in NE
12-10-2004 16:29:01
 Re: Liquid filled tires ???? in reply to wolfmantractor, 12-10-2004 16:04:31
I go along with that.
Calcium will damage nothing if it doesn't touch it. Replace the derned stems once in awhile. Geeeze!
Allan
old
12-10-2004 15:19:18
Depending on the tractor/loader it can almost be a must do thing. My loader tractor with out fluid wouldn"t do much work.
old fashioned farmer
12-10-2004 15:07:03
Howdy,
Pros: Traction
Cons:
The 485.00 per rim the tractor's owner has
to spend on new rear rims for his JD M all because his uncle wanted that "cheap" extra
traction many years ago.
God bless,
--old fashioned farmer
Indydirtfarmer
12-10-2004 13:09:36
Can you say "Can of worms"? 'Cause you just opened one (again). This is the most talked about issue on this board from time to time. There are more opinions on this that grains of sand on all the earths deserts....
SO....Here's my $.02 worth.
Tractors need weight for traction or stability. Liquid is cheaper (in most cases) than cast iron weights, as well as providing that weight at a lower center of gravity. In some cases, that tractor may be OVER weighted with the rear (or front) wheels full of fluid.
There are several choices for filling tires. One is Calcium Chloride mixed with water. This is a very corosive solution. Quite possibly, that is what is in your tires. (Or at least once was, causing the rusting of your rims) Cal. Chlor. makes water heavier than straight water. It ends up at about 10 pounds per gallon. (as opposed to roughly 8 PPG for pure water)
Another choice used quite frequently is Methyl Alcohol. (Windshield washer solution) That is what I use. It is non-corosive, and will end up costing roughly the same ammount as cal/chlor if bought in bulk.
There are several other options too. "Rim-Guard", a by-product of sugar beet production is becoming popular. Old anti-freeze, or even new anti-freeze is being used. A better choice would be the environmentaly friendly non glycol anti-freeze available nowdays.
Some people even use straight water. That would need to be removed COMPLETELY for winter, if you live in an area where it freezes. (Who doesn't?)
Tires need to be filled untill the fluid is just above the top of the rim.
Now the fight starts..... ..John
Allan in NE
12-10-2004 13:17:22
 Re: Liquid filled tires ???? in reply to Indydirtfarmer, 12-10-2004 13:09:36
Not me John,
'Cause I agree with yas..... .
Allan
Indydirtfarmer
12-10-2004 18:38:28
 Re: Liquid filled tires ???? in reply to Allan in NE, 12-10-2004 13:17:22
This just ain't as much fun without TheREALRon and his sharp stick..... .John
TheRealRon
12-10-2004 21:53:37
 Re: Liquid filled tires ???? in reply to Indydirtfarmer, 12-10-2004 18:38:28
Ya lookin for me big un?
Sawtooth
12-10-2004 12:56:46
The "pros" are obvious, more traction when you need it. The "cons" include the tendancy to rust the rims over time as well as the tires will sweat like a glass of cold water in summer when the air temp. exceeds the fluid temp.
Randall Higgins
12-10-2004 12:53:36
I did a search and found some info on the liquid-filled tires ( I guess I should have done that FIRST ! ) but I still a bit confused. Both wheels are corroded badly around the valve stem, in fact there is a 3 inch hole in one rim and the inner tube is bulging out !!
That will be my first repair job on this thing.
Any input?
Thanks.
Rusty Scupper
12-10-2004 14:20:27
 Re: Liquid filled tires ???? in reply to Randall Higgins, 12-10-2004 12:53:36
Not an expert, but talked to my deer hunting buddy who is a deere service manager. He said that Tire shops will come out, pump the liquid out, fix the rim, put in a new tube, pump back the liquid. He estimated the cost to be about $150 per tire. It sounds like your rim is a little more worse for wear than how I described mine.
Edchainsaw
12-10-2004 18:47:30
 Re: Liquid filled tires ???? in reply to Rusty Scupper, 12-10-2004 14:20:27
PRO * yes just one cheap weight
CONS 1 it does not take 40yrs to rust out a rim.. 2 checking air in the tire takes a special tire gauge from then on
3 if you do not change the valve core every year you will have a leak AND possible to be stuck in the tube---oh and some tires in the 70's and 80's were mounted tubeless with fluid.-- ours lasted 3yrs before it rotted out.
4 if you dont want all that weight all the time... too bad your stuck.
5 flat tires in the field resault in a dead spot in the field and cost of replacing the lost fluid (cast wieghts are a one time expence)
JMS/MN
12-11-2004 00:49:36
 Re: Liquid filled tires ???? in reply to Edchainsaw, 12-10-2004 18:47:30
It does not take a special gauge to check tire pressure- just make sure the valve is at a position above 10-2 o'clock, so the valve is above the fluid line. A bit of fluid in the gauge is not going to ruin it. And you don't need to put in a new valve core every year- that is nonsense! I have tractors with 30-40 year old valve cores. The vast majority of tractors in this country, for many decades, have been run with CC in the tires- but I guess all of us full-time farmers have just been wrong for all these years..... .
Edchainsaw
12-11-2004 15:01:22
 Re: Liquid filled tires ???? in reply to JMS/MN, 12-11-2004 00:49:36
well I am a full time farmer... dont do notill dont do strip till. I have farmed for a lot of years and saw several times fuild problems with the working tractors and a lot more with our antique tractors. cacl fliud doesnt register correctly on a non fluid gauge I worked for a tire dealer for a week to help him while he was recovering from a bleeding ulcer. and yes they will harm them if you do not clean them at the time.. you need to try.
Deere4100
01-18-2005 15:54:57
 Re: Liquid filled tires ???? in reply to Edchainsaw, 12-11-2004 15:01:22
I gummed up a gauge with CC the first time I used it. It was an expensive gauge too. How do you clean a gauge after testing pressure with a liquid filled tire so it doesn"t corrode?
Indydirtfarmer
12-11-2004 04:41:14
Farmer (YES, FULL-TIME FARMERS) plowed, disced, and cultivated for YEARS... Now a large majority are going to strip till. no till and other methods. That doesn't make all the farmers in the past WRONG....It just means times change and so do the ways we do things.
I farm on the fringes of a metro area. I have to deal with trash and junk in the fields. People throw all sorts of stuff off the roads and into my crops. I get (way too many) flats on a regular basis. I had to find something that wasn't so corosive. Also, when I was filling tires with cal. chlor., I ended up with more weight than I actually needed. The Methlyl Alcohol gives me more than I need too, but on a typical 20.8x38 rear tire, using Methyl alcohol cuts that weight by some 190 lbs per wheel.
On my loader tractor, I run cal. chlor and a stack of weights on each wheel. I need all the weight I can get there.
Point is, We can tailor the weight, and deal with special circumstances with various kinds of fluid in the tires. John
steveormary
12-10-2004 21:13:44
We always used the CC. No real problems. Had to patch a couple rims where the valve stem was.
