Tractor Talk Discussion Forum
OT - Bad Battery?
Irv
12-12-2004 20:38:19
My 94 K Blazer didn't want to start today. I jumped it and it started right up. I noticed then that the alternator was only pushing about 12-13 volts according to the dash gage. I looked at the battery and it was several years old. I replaced it. Now the gage shows 14 volts - straight up like it did before. Could this be caused by the battery being old - acting as a drain? Or should I look for another cause? Is the new battery just masking a problem that will reappear? Thanx, Irv
Leland
12-13-2004 19:34:00
 Re: OT - Bad Battery? in reply to Irv, 12-12-2004 20:38:19
I always replace them every 3-4 years that way I don't get a phone call from wife when I am 45 miles away and her car won't start, worth it for me just so I don't have to worry.
lucass
12-13-2004 08:15:38
a bad battery can make your charging system look like its bad when its good. lucass
Bob - MI
12-13-2004 07:49:01
You didn"t say how old the battery was but it seems that your charging system is working well as you see the difference on voltage output. I live in the great white north in Michigan and it seems that you made the right choice. When I was younger I never understood why my father was such an advocate for new batteries when a problem cropped up. Now I am pretty much the same way and my kids are rolling their eyes when I start talking about replacing batteries at some frequency. Factory guys I have heard have suggested every 4 years but I start getting uneasy around 6.
Hugh MacKay
12-13-2004 06:40:19
Irv: The others have said it all, you made the right move. Now place the old battery in a warm spot. To satisfy your self, put it in a tractor sometime. They don't tend to be so far away that a jump start is costly. I do this with batteries that I question whether life is gone.
txblu
12-13-2004 06:24:18
Supporting other comments and my experiences.
1. First sign of battery trouble, get another period.
2. Winter onset brings out the bad characters in your battery so expect to have a marginal battery show it's colors then.
Mark
thurlow
12-13-2004 07:05:02
 Re: OT - Bad Battery? in reply to txblu, 12-13-2004 06:24:18
My experience: Seem to notice a difference in the "way batteries fail" in cars and trucks. Until about 20-25 years ago, you might be aware of a slow decline in performance.....might drag or grunt or you might have to turn the key on and off a few times, but it still might start the vehicle for several weeks/months. The last few I've replaced, didn't even know I was having a problem until one morning when they were completely dead and had worked fine the day before. I attribute it to the way they're used; even with the key off, there's still a constant power drain.
txblu
12-13-2004 08:13:19
 Re: OT - Bad Battery? in reply to thurlow, 12-13-2004 07:05:02
Don't know what it is. I figure once a battery passes the 3 yr mark, it will fail regardless of how long it's supposed to last.
But I am delightfully surprised (knock on wood) the Mopar OEM in my 98 Dodge truck is still a purrin.
Wonder if the 140 amp alternator has anything to do with it?
Mark
Mark - IN.
12-13-2004 05:40:37
Could be either, or both. Battery was old anyway, you did the most common thing for the most common cause, replaced what appears to be a weak or dying battery. May not have another problem.
Willy-N
12-12-2004 21:29:50
Sounded like you had a dead cell in the Battry. Good choice with winter coming on! Lot cheaper than a towing bill or being stranded. Could have been dirty battry terminals but now you have it corrected. Mark H.
old
12-12-2004 21:06:22
Very good chance that the battery is going south on you.
