Tractor Talk Discussion Forum
OT , FORD F-250 POWER STEERING
FARMIN RED
12-13-2004 13:56:04
I have noticed latley now that it is cold that my power steering on my f-250 is hard to turn when I first start it up. when the truck is sitting still the steering is very tight, but once I start rolling the steering is fine. When I have driven about three or four blocks and stop, put it in park and turn it from lock to lock it seems to be alot better. Is there a problem here or is it just me and the cold weather?
fred kobs
12-14-2004 16:41:47
 Re: OT , FORD F-250 POWER STEERING in reply to FARMIN RED, 12-13-2004 13:56:04
hey farmin, there is a relief valve in the pump on those, i think it's the fitting behind the hi press. hose. takes a couple o rings to remove and clean it out. unscrew the hi press. line and then the threaded piece after that is the valve(i think) or replace pump for @$30 for a reman...just need a special puller to get pump off bracket Fred
Engineer20
12-13-2004 17:58:45
Hello Farmin Red,
Ford has never been famous for their power steering. My F250 use to squeal all of the time. My buddys does the same thing. Did you make sure the fluid is full?
