Tractor Talk Discussion Forum
OT - trailer weight capacity
aFORDable
12-13-2004 18:53:52
Dumb question but I'm old enough to ask and not care and really don't know! A dual axel trailer has 7000lb. axles. Does that mean it is rated to haul up to 7000 lb. or 14000 lb.? ps I don't post often but do read many post. I enjoy the info that can be picked up from this site. May all of you have a peaceful and great holiday season.
paul
12-13-2004 23:10:22
 Re: OT - trailer weight capacity in reply to aFORDable, 12-13-2004 18:53:52
Each axle can handle it rated weight. So, each axle can carry 7000, or 2 can handle 14,000.
as others say, the whole trailer likely will have less carry capacty than the axles - esp with such a stout axle. The tires, hitch, and so on each have their own rating, and the trailer will be rated to the lowest item.
Also, the weight of the trailer counts against you, so you can't carry a load weighing the rated weight - your total weight includes the weight of the trailer. You likely know that, but the wording of your question left it open... ;)
On the other hand, I hear you can combine the tounge weight rating & the axle rating to get the total weight. For example, if you have (2) 3000# axles and the trailer hitch is rated for 500# weight, the trailer can be rated for 6500#. I'm not smart enough to know if that really is true.....
--->Paul
Davis In SC
12-13-2004 20:53:50
My gooseneck has (2) 7K axles, but it is rated as 12K, not 14K, due to tires.
Mike M
12-14-2004 05:23:53
 Re: OT - trailer weight capacity in reply to Davis In SC, 12-13-2004 20:53:50
Since you have a gooseneck trailer you can haul up to that full 12K rating without worry about trailer weight because you are not limited by tongue weight and can transfer more weight to the truck.
Willy-N
12-13-2004 19:22:47
They rate trailers with both axles so that would be rated for 7,000 lbs (3,500 lbs per axle)total including the weight of the trailer itself. So if the trailer weighs 1,500 lbs you can carry 5,500 lbs and not be over loaded "Gross Trailer Weight" wise. You need to go by the GWR of the trailer to be sure and it should be on the "Data Plate" on the frame. Mark H.
Willy-N PS
12-13-2004 19:24:49
 Re: OT - trailer weight capacity in reply to Willy-N, 12-13-2004 19:22:47
That is how my Tandom Axle Trailer is Rated. Mark H.
johndeeregene
12-13-2004 19:17:13
it means that the axles are rated at 7000 each or 14,000 gross trailer weight.
the problem you will have is getting four tires to be rated at that weight also. cause you can legally only haul what your tires are rated at also. most class E tires at 3000 lds per tire. so you can only legally haul 12000. so be sure to look at your tires also cause the DOT will diffently look at them. johndeeregene
