Tractor Talk Discussion Forum
Re: Rear tire ballast
buickanddeere
12-15-2004 17:26:39
The foam used in our manlift, boom truck etc vehicle tires at work is a very dense and heavy product. It has to be at least as heavy as filling to 80% with windshield washer fluid. Doesn't ever go flat either.
Indydirtfarmer
12-16-2004 03:51:59
 Re: Rear tire ballast in reply to buickanddeere, 12-15-2004 17:26:39
Also, there are several brands of foam-fill on the market nowdays. Some is more dense than others. Some is heavier/lighter than others. There are a few that advertise a "better ride" than some other choices.
I'm seriously contemplating using foam filled tires on one of my tractor next summer. It spends several hundred hours each year bush hogging commercial (inter-city) property for a real estate broker I do business with. I average around 10 flats a summer with conventional air/fluid filled tires. There's got to be a better way..... John
txblu...John!!!
12-16-2004 05:35:21
 Re: Rear tire ballast in reply to Indydirtfarmer, 12-16-2004 03:51:59
Put new rubber on this recently purchased tractor. Did it myself. Upon removing the tube, I discovered a liner between the tube and tire. It consisted of a lot (8?)of plies and vulcanized rubber to hold it in place. The edges were tapered to fit against the tire's sidewall.
Never saw them before but assumed they were for the problem you are experiencing with flats.
Maybe a good ag tire store knows of them and could check it out.
Mark
farmallforever
12-16-2004 08:16:14
 Re: Rear tire ballast in reply to txblu...John!!!, 12-16-2004 05:35:21
that is called a reliner they were great and still are if you can find them we had a lot of thornapples in our pasture and that would ruin lots of tires but liquid ruins rims not tires so they wont help for weight.
txblu
12-16-2004 10:37:45
 Re: Rear tire ballast in reply to farmallforever, 12-16-2004 08:16:14
On the liquid. Our local tire guys use antifreeze solution. More expensive I know, but no rust problems.
Mrk
Indydirtfarmer
12-16-2004 06:17:06
I've seen a set of back-hoe rear tires done that way. (Belongs to a building demolition contractor) A couple things come to mind. One, I'm going to continue to use this tractor on the farm also. It will be for hay work mostly. The multi-ply "tread liner" made for an extremely stiff tire. That might not be that much of an issue. The other thing is, most of my flats seem to be from cut sidewalls. Not ALL of them mind you). I'm either going with foam-filled, or "slime filled" and cast weights. (This will be on a new tractor...It will be replacing the 2440 I just painted for bush hogging...GOTTA HAVE A CAB!) John
txblu
12-16-2004 10:36:02
 Re: Rear tire ballast in reply to Indydirtfarmer, 12-16-2004 06:17:06
You'll get clostafobia.....ya ya ye ya ya. LOL
I don't have a cab, if for no other reason, my stuff requires my constant TLC and with a cab, the door would be open all the time with me on and off constantly.
