Tractor Talk Discussion Forum
Trailer Surge Brake Master Cylinder
jdabg
12-20-2004 21:17:52
The master cylinder on my trailer is all rusted up. Where can I get parts or a new one? No part #'s on it.
Unimog
12-21-2004 13:52:56
 Re: Trailer Surge Brake Master Cylinder in reply to jdabg, 12-20-2004 21:17:52
Try www.whitepost.com They rebuild all types of
master, slave, wheel cyls. and calipers. They
sleeve them with brass or stainless and warrant
them for life I believe. You can get a quote in
a day or so from their web page as well as other
details like shipping and turnaround time. Not
cheap, but another option.
wrenchturner
12-21-2004 08:06:11
try a company called rigid hitch, they have almost anything you need for trailers
Nolan
12-21-2004 05:48:45
I've found Champion to have most of the master cylinders and rebuild kits.
VADAVE
12-21-2004 03:51:27
Call the trailer manufacturer with the model number of the trailer and they should be able to help.
Here"s another suggestion. A little more expensive but also better (I think). Surge brakes are just hydraulic brakes, why not replace the rusted master cylinder with a electric pump? These are available from most of the axle and brake manufacturers--I have one from Dexter. They are activated by a electric brake controller which means you do not have to worry about backing up. It also means you stop the lurching on a down grade. These pumps are smaller then a laptop computer and there are models to handle up to 3 axles.
What about the old master cylinder? Well once it is disconnceted it is just a coupler and you could just leave it, or you could cut it off and weld/bolt on a new coupler.
