Tractor Talk Discussion Forum
Problem on new steering hand pump on 574IH
shocker
12-25-2004 11:36:37
I just put a brand new hand pump on my 574 now it is hard to turn the steering wheel(compared to the leaky old one)will this get better or should i try to get another one since it is only guaranteed 30 days.
Bernard le mécano
12-26-2004 12:30:02
 Re: Problem on new steering hand pump on 574IH in reply to shocker, 12-25-2004 11:36:37
Hi, did the valve come with all the fittings? It have a steel ball in a hole, may be the ball is out. May be the valve is not timed or the flow-divider is stuck. Check with the engine running, hold the remote lever and turn the steering in same time. If it work ok, it's the divider Bernard le mécano Québec Canada
