Tractor Talk Discussion Forum
Off Topic Truck tires
JD Jack
12-28-2004 17:09:42
Not sure if this is the right place for this, but here it is... I have a 99 GMC Sierra 1500 with the extended cab. I was hoping to get some suggestions for a good all terrain tire for this truck. I live in northern New York and use this truck on pavement and dirt roads, fields and in snow. I want something that will give good grip, but won't make a ton of noise going down the highway. What do you use that seems to work good. What price range should I expect to pay? Thanks for your input!
tortmort
12-29-2004 08:08:48
 Re: Off Topic Truck tires in reply to JD Jack, 12-28-2004 17:09:42
Michelin XPS Traction. Cost $$$ but last much longer. UPS trucks use the XPS out here. I bought five from Costco. I have 235-85-16 load range E. When I bought tires for my car I asked the sales person what is the best truck tire he had and he said XPS by far. I checked on the internet and confirmed what he told me. Costco had the best price but they had to order them.
thejdman01
12-29-2004 14:05:35
 Re: Off Topic Truck tires in reply to tortmort, 12-29-2004 08:08:48
firestone steetex radial a/t 265 76 r16 is about the biggest you want to run on a stock rim its what i run on a 3/4 and 1 ton gmc absolutly love them tires also i highly highly highly recommend equal in all tires i run them on everything from my pickup to my semi always found great tire wear even on my old 86 gmc farm beater that i know has alot of loosness in the sterring and when i used equal took alot of vibration out of the steering wheel it balances continusly not like a weight that stays in 1 spot and never changes equal balances and can change w/road speed inflation everything
EQUAL Tire Balancer
EQUAL is a dry polymer tire balancer that can be injected into tires directly through the valve stem. Once inside the tire cavity, EQUAL granules are forced across the tread width and around the circumference of the tire, responding to force variations caused by non-uniformities within the tire, the road and even the load. EQUAL balances as the load and speed change to maintain a vibration-free, stable footprint.
EQUAL tire balancer reduces vibration in 3 ways. It compensates for irregularities found in both the tire and wheel assembly and at the tire road surface contact. EQUAL also has the ability to adapt, respond and dampen vibrations at the tire footprint
EQUAL is the tire balancer that will save you money. Even tire wear means thousands of extra miles on each and every tire. Less shimmy means fewer alignments and fewer component and maintenance problems caused by vibration. And a one-time installation of EQUAL means you'll never have to pay to re-balance your tires again.
Willy-N
12-29-2004 07:47:15
Boy you guys get some great deals on tires! The ones on my Dodge 16 x 285s on 10 inch rims cost $850.00 including siping and being mounted rims not included! The 9.00 X 16s for my Power Wagon with tubes and flaps were almost $850.00 too! Mark H.
bob/wis
12-29-2004 05:13:38
Man not much said about coopers. I have ran them a alot on my trucks. Mostly at thrm times they was 2 wheel drives. I loved the tracton of the AT's and they lasted along time. These was farm trucks, I will be needing a set of new skins for my diesel in the next month. Yeap I will be putting coopers on it. I can also go to walmart superstore and ahve any of the kelly line of tires too put on. But, they make nice car tires. Kelly springfeild makes tire that go by Kelly, douglas and goodyear. Later Bob
BUDD
12-29-2004 03:08:12
JD Jack;
I have a 84 1/2 ton Chevy 4x4 (short bed). I put on a set of Chaparral's 33x1250x15 (these are the same as the BFG AT) 7 years ago. I run anywhere from 10000 to 15000 miles a year. I just replaced these tires this past fall because the inside side walls gave out. These tires were just down to the wear bar on the tread so they were ready to be replaced. The reason that the side walls went was the fact that I run low air pressure (25 psi front and 20 rear), but I believe this is also why I got so many miles out of them. These tires are a harder compound so the wear is better. These tires are very quite driving down the road. I went to a Dunlap mud tire this time and am sorry I did. The Chaparral's were a good all around tire. The cost is $550 for 4 installed for me.
Just some info BUDD)"":""(
jim
12-28-2004 22:10:00
Whatever you get, don"t get Goodyear, I mean goodforyear. Were good tires for about a year then started to get out of round and shake the P*** out of you. NEVER AGAIN!! Got michilens on roadhazard and no problems, much better ride. Had BFG longtrail on before the goodyears. They were decent tires, so-so traction past 1/2 wore.
Leland
12-28-2004 22:01:56
FYI michelin now owns BFG thats the only reason why those tires inproved. But I agree the LTXs 10 plys are a great tire wore out a couple of pairs on work truck.
Dug
12-28-2004 20:17:12
Hello Jack,
Lots of good advice, I agree whole-heartedly with the BFG AT, however you may want to consider the BFG Mud Terrain. Much more aggressive, but a little noisier. However, they are far and away the "baddest" looking tires on the market!
Dug
TomTX
12-28-2004 19:42:11
I have switched several years ago to Michelin LTX M&S. Have had 2 sets - will not have anything else now.
Scott Green
12-30-2004 16:42:40
 Re: Off Topic Truck tires in reply to TomTX, 12-28-2004 19:42:11
Have had same experience with same tires. (Michelin LTX M&S). Will not buy anything else. They grip , clean , ride , and wear very well.
buickanddeere
12-28-2004 20:37:16
Same LTX M&S on the truck my wife and children use. Nothing but the best. Purchased the load range E which is "10 ply". Has three belts of steel over the tread for good road hazard protection. Good wear rating, wet road traction & handling. In the fall we usually put a new pair on the front and move the partly worn front tires to the back.
Ken S.
12-28-2004 19:39:27
I have really good luck with StarFire Radial LT made by Cooper Tires. Midrange for price and not noisey at all on the highway.
jhill
12-28-2004 19:23:07
I like the BFG T/As also.I have gone thru at least 6 sets over the last 10 yrs. I get at least 60,000 miles. Great traction and low noise. I have always bought mine from a BFG dealer. I am glad to hear others have good experience with sams I have shyed away from them myselfand bought for comparable prices other places.
Rod (NH)
12-28-2004 18:02:05
Hi Jack,
I agree with the others on the BFG ATs.
I went through a similar decision-making process this past fall for a Toyota Tacoma 4WD. My original tires had about had it and I was never really that satisfied with them in snow. I decided on BF Goodrich All-Terrains. I had been concerned with the possibility of excessive highway noise because of the agressive appearing tread but have found they make no more noise than my original equipment tires. Not objectionable at all. They are pricey indeed at about $175 per tire for the LT265/70R16 size. They are the light truck (LT) series and not the P (passenger car series) so they have a heavier sidewall. Nice deep tread. I haven't given them a real good snow test yet this year for lack of snow so far, but I expect they will do about as well as anything else. They were highly recommended to me and I see they are standard equipment tires on Hummers.
third party image Rod
Jon17
12-28-2004 17:57:46
The BFG All Terrain is a classic tire. BFG also makes the Long Trail T/A which is a great all weather tire, but not really for off road use. You are looking at probably a 26575r16 for your pickup. Though your truck calls for a passenger rated tire I would put a least a load range C tire on it. Another good option would be the BFG Rugged Trail. If money is no object and you plan on keeping your pickup for another 100,000 miles get yourself a set of Michelin LTX M&S. I have seen many of these tires run over 100,000 miles with very little maintenance, but it is an investment. HTH JohnG
D.L.
12-28-2004 17:46:42
I've had excellent results from BF Goodrich tires... I run "Commercial LT's" on my 1 ton, (16" 10 ply's cost about $90 @ sam's & not uncommon to get 50 - 60K miles on them... conventional all-season radials), have run various BFG's on our passenger cars, and am most impressed with their All Terrain TA's... a big, aggressive tire with excellent wear, traction, & low noise. We've got more than 60 K miles on the ones on the wife's suburban (has full-time 4wd... notorious tire eater)... have never been rotated & have had no problems what-so-ever with them!!! Obviously, price depends on size, but for our 31" x 10.5" x 15", I think we paid about $125. I'll never own any other tire!!! HTH
Regards, DL
Bob - MI
12-28-2004 17:46:36
JD,
I just bought new tires for my wife"s "98 Grand Cherokee and I found the best information at Tire Rack"s website. I reviewed lots of choices but they have a nice comparison system that gives performance ratings as well as customer reviews. In addition, I shopped locally and was told by the Belle Tire store here that the reviews on Tire Rack are usually very accurate.
Because of this and with an eye on performance and price I bought a set of Firestone Destination LE 225-75-15 out the door with tax and road warranty for $352.00
Firestone store wanted $475.00 plus road hazard warranty. All other choices were about $450.00 for a set except for Sam"s Club at $350.00 for BF Goodrich. BFG"s had lower treadwear rating and lower Tire Rack reviews. I have had very good luck with Sam"s Club service and if I could get the same tires there I would go back.
No matter what the sale was Sears was always high.
Best of luck.
Davis In SC
12-28-2004 18:13:49
 Re: Off Topic Truck tires in reply to Bob - MI, 12-28-2004 17:46:36
I used to buy tires at Sears, put a set of BFG M+S tires on Truck on a Fri, was under truck greasing it on Sat, & saw a big bubble on inside sidewall of one tire. Went straight back to Sears, manager would not "Break up a set" to give me a replacement... Had to wait for him to order one... I will not buy anything a Sears Auto Store !!! Then I discovered Sam's is much Cheaper... Buy all my tires at Sam's now...
thurlow
12-29-2004 06:58:00
 Re: Off Topic Truck tires in reply to Davis In SC, 12-28-2004 18:13:49
RE: Sam's Club..... ..have a set of Michelins on my wife's car; about $120 each as I recall. When the tread was about half gone (last year), one of them developed a huge ballon.....too bad to drive on. Put the spare on and carried it back to Sam's. Couldn't find the paper work to prove where I had bought it; couldn't remember which store (we trade at 3 different ones). Girl at service desk spent about 10 minutes on computer, came up purchase date, price, etc. Got 2 new tires (also replaced the other tire on the same axle so they would "match") at no cost to me. When I need tires, I look at Sam's first..... ...
barryinmn
12-29-2004 10:45:42
 Re: Off Topic Truck tires in reply to thurlow, 12-29-2004 06:58:00
I agree on Sams: bought 4 Michelin 1's on car & got a irreparable cut in sidewall @ 30K mi Sams replaced all 4 no charge matched set. Never wore them out on car - traded it before they could wear out. Pickup has Michelin LTX AT's 75K mi & still going strong. They have needed rotate & balance 2X.
