Tractor Talk Discussion Forum
4430 reverse went out and can't get it in c or d
West
01-01-2005 21:02:48
i was plowing snow with a 9' grader blade in reverse (b range)when i heard a pop. reverse stop workin in any of the ranges and can't get into c or d range.....Any ideas as to what happened?
West
01-24-2005 01:40:54
 Re: 4430 reverse went out and can't get it in c o in reply to West, 01-01-2005 21:02:48
i finally took the inspection plate off the trans and just my luck i shattered a pinion gear which operates reverse and the reasin why i could not get into c or d range is because a piece of the gear had gottin stuck in the shifting forks. has anyone else ever experienced this problem and if so about how much would it cost in parts if did the work myself.
edchainsaw
01-02-2005 17:53:13
sounds like what happend to our 4630 back in '81.
the 2 small bolts at the front of the transmition pull backward when you are in reverse--when they get a bit old or strained POP! and that drops that shaft down... you might have a range or 2 as we did.. but dont move it far... the farther you go the more damage you do... and it cost us-- 18,000 in 1981.....
deerly parted
01-02-2005 06:06:03
Sounds like exactly what hapened to our 4440 a couple years ago. Transmission gear broke a tooth. About $12,000 repair later and it's back at home ready for another 4000 hours hopefully.
