Tractor Talk Discussion Forum
9N starter motor
Al Mingus
01-03-2005 15:30:23
When removing the starter motor on a (9N/2N) do you have to split the front end at the flywheel to get to the hold down bolts. I don't see any on the exterior side. Thanks to anyone that could give me a clue.
Leroy
01-03-2005 15:39:45
 Re: 9N starter motor in reply to Al Mingus, 01-03-2005 15:30:23
The bolts that hold the starter on are what you se stiking out the front end of starter 5/16' bolt, loosen those enough to slightly pull out and put a 5/16' nut on end of bolt to keep from coming apart. Check the 9-2-8N board for more info. Hundreds of posts on this in curant pages or archives
Al Mingus
01-03-2005 15:45:36
 Re: 9N starter motor in reply to Leroy, 01-03-2005 15:39:45
Thanks Leroy, anytime your in the Esparto Ca. area stop by.
